Author Topic: would this router work for tmolding or does anyone know of a cordless router ?  (Read 3824 times)
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
i am looking for a cordless router to cut wood for t molding doe's anyone think this would work ?
http://www.homedepot.com/p/Ryobi-18-Volt-ONE-Trim-Router-P600/100342147#specifications
  • Last login:Yesterday at 03:17:50 pm
If all you're doing is the CP for your DK/Mario cab it MIGHT work.
Battery power + trim router (intended for use on laminate) + T-molding bit = not likely to work for too long.
I'd definitely advise against using that setup for a full-size-cab side.
Consider renting (or buying used) a good full-size corded router.
matt4949
I agree with PL1. Good routers can be found on craigslist for 20 -30 bucks all the time.
mebronx2000
the money is not the issue the cord is !! i want a cordless one ! thanks  :notworthy:
matt4949
There are no good cordless routers.
shponglefan
^ This.
Slippyblade
For a router to work properly it needs high RPM and high torque.  Battery power cannot supply either of those for very long.  I love the Ryobi 1+ series, I have several of them myself.  I'd not bother with this router.
JDFan
Just realize that the one you linked is just the router assembly --- NO BATTERY OR CHARGER INCLUDED so expect to pay another $60-$80 for the battery and charger ( ie. This $60 unit http://www.homedepot.com/p/Ryobi-18-Volt-One-Lithium-Ion-Upgrade-Kit-P128/203466924#.UnenJxDOT40 ) -- so the entire thing without any bits and only a single battery will be running $120 !!! (you usually want at least 2 batteries if using it very often so you don't have to wait 4 hours for it to recharge in the middle of a job -- which would mean this $130 dual battery pack http://www.homedepot.com/p/Unbranded-18-Volt-Compact-Lithium-Plus-and-Charger-Kit-2-Pack-P109-117/204100851#.UneokBDOT40  )
« Last Edit: November 04, 2013, 09:01:48 am by JDFan »
mebronx2000
i will take your guys  advice !! thanks for all your help ! :notworthy: :applaud: :cheers:
kahlid74
  • Gaming for a better future!
    • GamersAnon
Late to the party but yeah, corded router will serve you better with what you're planning to do.
