Author Topic: .  (Read 2266 times)
ChanceKJ
« on: November 02, 2013, 07:04:34 pm »
« Last Edit: March 18, 2021, 10:40:11 pm by ChanceKJ »
gamepimp
  • Last login:December 20, 2025, 10:42:56 pm
Re: Scanline generators? Thoughts?
« Reply #1 on: November 02, 2013, 07:29:31 pm »
I have the RetroVGA SLG. Love it and would highly recommend. The guy is in Brazil. But he takes PayPal and ships to the US. Check it out...
http://www.brunofreitas.com/node/36
rCadeGaming
  • Just call me Rob!
« Reply #2 on: November 04, 2013, 12:20:03 am »
They don't really replicate real scanlines very well.  I've only personally used an SLG-3000, but there isn't anything much different the others could do that it doesn't.
If you must display 240p on a flat-panel, HLSL will give you much better results from MAME than a hardware solution.  If not using MAME, hardware is sometimes the only option.  A high-quality upscaler like an X-RGB mini may do a better job, not sure.  Pretty pricey anyways.
1080i is not so hot either.  Sounds like you're just using what's lying around.  It's likely to be laggy and very poor for gaming anyhow.
ChanceKJ
« Reply #3 on: November 04, 2013, 10:02:21 pm »
« Last Edit: March 18, 2021, 10:40:27 pm by ChanceKJ »
