Author Topic: u-hid shift behavior  (Read 1168 times)
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« on: October 28, 2013, 11:36:19 pm »
hey guys,
i just did a massive rewiring project for my panel, man was it a mess under there!  i'm loving all my new components from Ultimarc (thanks Andy!) but have recently seen some weirdness.
seems the shift button i assigned, 1, is sending m,multiple keystrokes.  it works fine as a shift, hold 1, press my button 4, it sends "P" for pause.  but if i just tap "1", in notepad, it sends a one, followed an instance later by 8 rapid fire 1's (testing in notepad).  this seems to be doing it for anyt button i set up as a shift.  i tried setting "2" as a shift and it's doing the same thing.
i've tried setting the "down action" in the u-hid config to both "normal primary" and "pulse primary" and they both are doing the same thing.
any thoughts on what might be going on?  thanks
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: u-hid shift behavior
« Reply #1 on: October 29, 2013, 02:52:41 pm »
The keycode should be sent (once) when the button is released if the pin is defined as the U-HID shift control. It is pulsed on release but if you have a very short keyboard auto-repeat time configured you might get multiple characters typed.
This should not affect gaming.
tony.silveira
    • my baby
« Reply #2 on: October 29, 2013, 05:08:29 pm »
thanks for the response andy.  it doesn't affect gaming but it's running wild in my front end.  as an example, i press '5' to bring up mala's menu.  if i go to sort games or select another game list, i press '1'.  with this issue, when i select a different game list, it rapidly starts whatever game is first on the list (the multiple key presses of '1').
i will check the auto-repeat time when i get home but it only is happening with teh shifted key, no others.  be they 'normal' or 'pulse.
but let me see when i get home.
EDIT:  that did her Andy, thanks a ton man!
« Last Edit: October 29, 2013, 11:52:14 pm by tony.silveira »
