Author Topic: XBox Powered Racing Cab  (Read 3603 times)
zelony
  • Last login:November 16, 2019, 04:00:12 pm
    • Green Chavez Law Firm
« on: October 18, 2013, 04:43:47 pm »
Hi all,
I just wanted to share my Xbox Powered Racing Cabinet build.  I will try to get some decent pictures up and give more detail to anyone who is interested.  For now, these are pictures I took with my phone.
This is a custom built X-Box powered sit down racing arcade. It is a converted Rush the Rock arcade.
It is powered by a modded original X-Box with a 320GB Hard Drive running N-Dure and XBMC front-end. The DVD drive still works, so you can use any X-Box game and copy it to the drive for faster loading.
The monitor is bright with great color saturation and is connected to an Ultimarc X-Box AV to Arcade monitor adapter. This connector provides an outstanding picture and I highly recommend their product.
The sound system consists of 4 surround speakers and a subwoofer all powered by a dedicated amp with volume and sub control.
The controls are all Happ arcade buttons wired directly to an X-Box Fanatec Racing Wheel that has been decased and permanently mounted in the arcade. The original arcade pedals have been tied into the controller as well as the steering wheel and force feedback. All controls are heavy duty arcade controls for long life and wear.
The Force-Feedback has been converted to work with the arcade motor for awesome and powerful force feedback effects. There is a dedicated power supply just for the force feedback motor and it is controlled by a heavy duty servo amplifier. I can adjust the force feedback either by using the built in controls of the Fanatec wheel or by adjusting the servo amplifier.
The whole system is controlled by a smart strip power adapter so that when you start the X-Box the whole system powers up.
Well Fed Games
  • Delicious!
Re: XBox Powered Racing Cab
« Reply #1 on: October 18, 2013, 05:03:56 pm »
Heh, nice. I have just been thinking how good a driving "brain" and OG Xbox makes for a driving cab, with the (arguably) best versions of Crazy Taxy and Outrun 2...
I see empty rush cabinets more than any other driving game, nice to see one put to such good use.
Generic Eric
« Reply #2 on: October 18, 2013, 05:45:55 pm »
Midtown Madness 3 FTW!
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
« Reply #3 on: October 19, 2013, 09:12:26 am »
This A nice cab :applaud:
but why don't you consider to put a XBOX360? or even better XBOX360 whit RGH...
« Last Edit: October 19, 2013, 09:14:30 am by jackiabu »
« Reply #4 on: October 19, 2013, 11:33:06 am »
Nice clean cab.   :cheers:
With the xbox, do you have any of the center wobbling issues that some of us using a servo amp with a pc Logitech wheel experience?
(if you're not familiar, the wheel wobbles back and forth when not held unless the centering feedback is turned way down)
zelony
« Reply #5 on: October 31, 2013, 04:54:41 pm »
I used an original XBOX because the graphics are better suited to the arcade monitor and there was an existing video adapter.  Also, I was able to put all the games on the hard drive which makes my life easier.
The wobble occurs based on the level of feedback sensitivity you set on the servo amplifier.
