Author Topic: Groovylinux Livecd works No Picture after Install. (Tabletop)  (Read 2039 times)
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
« on: October 07, 2013, 12:29:44 am »
Hello Everyone,
I have decided to make another machine but this time for full linux :)
I have a genuine tabletop i am restoring and would like to make it able to play standard and mame :)
Anyhow off track i am using a TV using S-video (and the picture is amazing!!!!!!!!!!!!)
My Issue is i am using a RadieonX550 and using the S-video out.
Now the live cd i am Selecting LCD Monitor because its the only mode that looked right and flawless at that!
All the games played perfectly and couldnt ask for anything better.
But after i install it it loads perfectly fine and i get the groovymame starting screen then everything goes black,
I am wondering if its the fact that its decided to use the DVI or VGA port
Or its sending an out of range signal to the monitor? (but normally if you did this it would display something other then black)
Any ideas guys?
Was really hard to find a 14inch Color tube!!!!!(like you have no idea in Australia)
epicfatigue
Help GroovyArcade TV RBG
« Reply #1 on: October 09, 2013, 06:20:39 am »
Hello everyone,
My setup is GrovyArcade running on x550 using Svideo out to TV.
Picture is perfect during install boot up bios etc etc
I have tryed everything to get this going.
When i use the live cd and select LCD it works perfectly but when i install it and then reboot i get the loading screen then nothing.
Please please please help i am dying to get this running and i dont want to use windows.
Calamity
  • Moderator
  • Last login:Today at 04:20:08 am
  • Quote me with care
Re: Help GroovyArcade TV RBG
« Reply #2 on: October 09, 2013, 01:09:39 pm »
Hi epicfatigue,
During boot, press escape as soon as the GroovyArcade logo shows up, it's possibly corrupting the video driver. Then get into video setup->video grub and disable the splash screen permanently.
I'm assuming you're aware that s-video will kill 'magic' of GroovyMAME regarding video timings, resolutions, etc.
Steps to create a log:
epicfatigue
Re: Groovylinux Livecd works No Picture after Install. (Tabletop)
« Reply #3 on: October 09, 2013, 10:43:38 pm »
Thanks Calamity i will try that tonight,
No i was not aware of that, but this is more or less as a work around until my game board is repaired :)
I plan on putting a PC crt in there when i find a suitable replacement !
