Author Topic: DIY monitor lift?  (Read 3950 times)
quizz_kid
  • Last login:January 01, 2016, 03:10:29 pm
  • In the year 20XX...
    • http://www.lovehulten.com
DIY monitor lift?
« on: August 22, 2013, 05:31:45 am »
Hi guys.
I'm planning to build a desk with a built in stealth monitor lift, James Bond style.
The basic idea is to keep the monitor hidden when not in use.
I'm looking for a DIY solution here I think, cause I don't think I could pull out more than say £150. Is this even possible?
Ideas are very appreciated!
Another idea is of course to find a ready-made lift and try to get sponsored...
//Quizz
CoryBee
  • Bopity Boopy
Re: DIY monitor lift?
« Reply #1 on: August 22, 2013, 05:56:14 am »
May I ask what is the application?
quizz_kid
« Reply #2 on: August 22, 2013, 06:17:09 am »
It's for a desk/workbench project I'm planning to start building when Revelation's finished.
  • Last login:December 19, 2025, 12:23:29 pm
« Reply #3 on: August 22, 2013, 09:55:42 am »
Someone had a jukebox project with a screen that popped up like that, but I can't find it now.
They were using a single linear actuator with guide rails to keep it straight.
http://www.surpluscenter.com/sort.asp?keyword=EALD&catname=electric&PAGELEN=20&PageNo=2
Depending on how heavy the whole apparatus is, you might get away with a power window setup:
http://www.surpluscenter.com/item.asp?item=5-1707-R&catname=electric
It would be cheaper and work faster than a linear actuator.
Looks like that one only travels less than a foot, so you'd have to use pulleys to get more travel.
Or since it doesn't have any limit switches, you could rebuild the thing to make it longer.
« Last Edit: August 22, 2013, 09:59:55 am by BadMouth »
Brian74
  • Last login:Yesterday at 03:34:41 pm
  • Yep... I built that!!
« Reply #4 on: August 22, 2013, 10:06:13 am »
Im looking to do the same thing, but with a 60" dlp tv. I also need to build something to drop my projector out of the ceiling.
Sent from my SGH-T989 using Tapatalk 2
  • Last login:December 19, 2025, 10:05:55 am
« Reply #5 on: August 22, 2013, 11:23:24 am »
I love stuff like this. I'm watching this with anticipation. Allow me to throw in my AJ approved "Subscribed!"
ark_ader
  • I glow in the dark.
« Reply #6 on: August 22, 2013, 03:55:55 pm »
I was looking at this idea as I have a 5 monitor setup (now three) and I wanted the displays to emerge like those end of bed TV cabinets.
The first problem was weight, but with a single monitor you could get away with using a hand screwdriver/drill motor.
If you have a workbench how about a sunken monitor into the desk with a perspex shield, and use a mirror.   ;D
quizz_kid
« Reply #7 on: August 23, 2013, 03:30:03 am »
Thanks for the tips guys. The mirror idea is interesting, but no  ;D
Found a cheap linear actuator, could it work with some mount modifications, say guide railing maybe?
http://www.ebay.com/itm/18-STROKE-665-LBS-24-VOLTS-DC-LINEAR-ACTUATOR-5-1785-/380454707164?pt=LH_DefaultDomain_0&hash=item5894de1fdc
« Last Edit: August 23, 2013, 04:03:22 am by quizz_kid »
« Reply #8 on: August 23, 2013, 10:17:18 am »
Looks like it will work, but keep in mind that it only moves .3"/sec
That means you're looking at a full minute of listening to gears grinding for full extension.
You don't need one to lift 665lbs, but it's not easy to find weaker/faster ones.
It's nice that this one has built-in limit switches.
I think the one in my cab (which rotates the monitor) was something like 1.5"/sec
It was from Surplus Center, but they discontinued that model.  :angry:
quizz_kid
« Reply #9 on: August 23, 2013, 11:00:26 am »
A minute? Well, the waiting is the funniest part, don't we think  ;)
Also, do I need a control box to operate the actuator, or can I make the controller switches myself? And 1min of pushing a button is a lot, can I have non-momentary switches maybe?
I still don't know how to make a guide rail though. Maybe I'll just buy the actuator and take it from there...
« Last Edit: August 23, 2013, 11:11:28 am by quizz_kid »
« Reply #10 on: August 23, 2013, 11:17:47 am »
A minute? Well, the waiting is the funniest part, don't we think  ;) Seriously, if the switches are momentary then 1 min is a lot of pushing. Can you make them non-momentary maybe?
This has built in limit switches.  You can wire up a plain old 3-way toggle switch to control it.
Wire the actuator to the middle two contacts, wire the top two and bottom two to your power source, but make one reversed.
quizz_kid
« Reply #11 on: August 23, 2013, 12:27:08 pm »
Thanks, that's good news friend! Appreciate the help, a lot!
« Reply #12 on: August 23, 2013, 05:35:40 pm »
OK, you have DaOld Mans attention.
quizz_kid
« Reply #13 on: August 24, 2013, 08:03:43 am »
DaOld attention is always good  ;)
