August 02, 2025, 08:43:20 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Video Games
through our link. Thank you!
Forum notices to gmail.com addresses are working. Microsoft addresses are still not.
The NEW Build Your Own Arcade Controls
Main
Software Forum
HLSL - can't get it to run?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: HLSL - can't get it to run? (Read 3662 times)
stuzza
Trade Count:
0
Full Member
Offline
Last login:May 13, 2025, 09:19:19 pm
I'm a llama!
on:
August 07, 2013, 11:19:25 pm »
I've been trying to get the new HLSL effects running in mame but for some reason I cannot get anything to happen? I have downloaded a full mame 0.148 set. I first tried with Groovymame but nothing happens (ie I see no effect when launching donkeykong via command line). I have since downloaded the official mame 0148 but still nothing happens. I have the hlsl folder with the files in it. I have created the mame.ini file and set hlsl to 1. I tried with both onboard intel graphics and have now added a Nvidia Geforce GT220. I have installed directx9c runtime and rebooted.
I'm running windows xp pro 32bit with a 19" LCD monitor. I'd just like to get the scanlines effect and maybe curve the edge of the screen slightly so it appears like a CRT.
Any help would be appreciated.
Logged
Monkeyvoodoo
Trade Count:
0
Full Member
Offline
Last login:November 16, 2024, 01:36:41 am
I swear I can stop at one. Or two.
Reply #1 on:
August 07, 2013, 11:36:02 pm »
Might want to look into your video card. It has to support shaders 3.0
Some onboard graphic chips support it, but some don't.
I have a similar problem, my test computer displays the effects but the unit going in the cabinet won't display to save my life.
Logged
Connorsdad
Trade Count:
0
Full Member
Offline
Last login:May 18, 2024, 04:28:42 pm
I want to build my own arcade controls!
Re: HLSL - can't get it to run?
Reply #2 on:
August 08, 2013, 02:09:22 am »
I couldn't get it to work with 148 either, not sure if it was my setup or 148 that was broken. HLSL works fine on 149, the problem with this version is you can't have dual display and HLSL enabled at the same time.
Sent from Amstrad CPC464
Logged
edekoning
Trade Count:
0
Full Member
Offline
Last login:November 10, 2022, 02:21:38 pm
Reply #3 on:
August 08, 2013, 03:12:34 am »
I had the same problem with 146. After I downloaded and installed DirectX 9 everything worked fine.
Logged
Builds:
Magneto (2013)
NES (2015)
X-Men (2020)
Binkles
Trade Count:
0
Full Member
Offline
Last login:May 05, 2017, 10:41:45 am
Reply #4 on:
August 13, 2013, 05:59:20 am »
If you can get the scanlines, should you also be able to mimic the curvature?
I've followed instructions, have the scan lines, but cannot get the curvature effects to work.
Logged
stuzza
Trade Count:
0
Full Member
Offline
I'm a llama!
Reply #5 on:
August 20, 2013, 01:17:21 am »
Ok I got it to work now. I had to install the full directx and not just directx 9c which I had done before. I have also changed the graphics card to a 9500GT. So now HLSL is working, however it makes the games run too slow on my system. With HLSL enabled the games drop to 76% speed. Would this be graphics card related? I am running Windows xp, 2GB RAM, C2D 2.8ghz, Geforce 9500GT.
Binkles - As for curvature, the curvature seems to work ok on my system (apart from the slowdown). I have only used the one set of HLSL settings so far though which I got from here:
http://shmups.system11.org/viewtopic.php?f=6&t=45026&start=240
I used the HLSL '91 Japan mode.
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Software Forum
