Author Topic: wells gardner S05F0000-000f vertical kit.  (Read 1558 times)
almalm
  • Last login:August 01, 2013, 12:53:07 pm
« on: July 31, 2013, 11:32:00 am »
Can someone tell me what the terminal strip and resistor consists of?
Ken Layton
  • Guru
  • Technician
Re: wells gardner S05F0000-000f vertical kit.
« Reply #1 on: July 31, 2013, 12:24:14 pm »
almalm
« Reply #2 on: August 01, 2013, 11:10:41 am »
Thanks You. I am a consumer electronic tech. I have been working 23 years in that field. Just recently I had a gentleman who runs gaming rooms ask if I would be interested in servicing these games. I have learned a little so far. One thing I am unclear about is this guy thinks he can just switch boards from 1 machine to the other. Some of these are different #'s. I think you have to have the right CRT and yoke for the chassis he wants fixed. Am I right ?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 01, 2013, 12:41:39 pm »
It's generally not a good idea to just "switch chassis" willy-nilly without regard to make/model. Yoke impedance and CRT pinout do matter as does whether the chassis needs an isolation transformer or not.
There are some "universal" replacement chassis made by Chinese and Korean companies that retrofit many chassis, but you need to be within certain specifications to work without blowing up the chassis. In other words, don't use a low impedance yoke with a chassis designed for high impedance.
