Author Topic: Looking for input  (Read 2579 times)
not_so_handy
  • Last login:January 20, 2016, 09:36:16 pm
Looking for input
« on: July 29, 2013, 10:46:38 am »
I would love to do a conversion to play some racing games.  But have no idea where to start.  I saw this cabinet come up online
http://london.kijiji.ca/c-buy-and-sell-video-games-consoles-other-Crazy-Taxi-Arcade-Machine-Project-W0QQAdIdZ505150020
What is a reasonable price to pay for a nonworking cabinet like this?  What kind of investment am I looking to get it up and running afterwards?
Any help would be appreciated as I am a complete noob with racers.  Maybe I am asking the wrong questions as well.
Jeff
Re: Looking for input
« Reply #1 on: July 29, 2013, 11:01:20 am »
Looks pretty good, I'd do $400 probably but racing cabs can get really expensive to tweak and get playing the way you want so be prepared to commit at least double that after the fact to PC, parts, etc.  Offer $250 and to take it away the next day, if it's still there in a week bump up.
  • Moderator
  • Last login:August 19, 2025, 03:10:32 pm
« Reply #2 on: July 29, 2013, 11:56:58 am »
I paid $50 for a gutted Virtual On cab without a monitor, but ended up with around $750 in it by the time I repainted, built the PC, added a PC steering wheel, etc.  I recently picked up an Initial D with working monitor for the same price, but it was from someone who just wanted it out of the way.
If I had it to do over again, knowing what I know now, I'd hold out for a Daytona or Sega Rally Model 2 cab and build Aganyte's interface utilize the original controls.  http://translate.google.com/translate?hl=en&ie=UTF8&prev=_t&rurl=translate.google.com&sl=fr&tl=en&twu=1&u=http://www.gamoover.net/tuto/l2m2-interfacer-un-ffb-et-volant-sega-model-12-avec-un-pc-ou-une-playstation-23  People seem extremely pleased with that particular setup.
There isn't a hack out there to use the force feedback motor in crazy taxi, so you're looking at building a new dash for a PC wheel, or buying a different arcade wheel and trying to hack it into that dashboard.  If you're ok not having force feedback, you can just swap potentiometers in that wheel and use it as it is.
Most of the time you go have to roll with the cab that presents itself though.
For that cab, at a minimum you're looking at:
1. Building a PC with enough horsepower to run the games you want to play.
have a look here: http://forum.arcadecontrols.com/index.php/topic,130988.msg1342049.html#msg1342049
2. Interfacing the arcade monitor to a PC if it works.  If not, squeezing a TV in place of the monitor
3. Replacing the potentiometers on the steering wheel and pedals with ones that work for your chosen interface.
(u-hid, Logitech wheel hack, etc.  See stickied driving cab thread)  You will have no force feedback.
                                      --or--
   Hacking up the current dashboard to incorporate a PC wheel such as the Logitech G27.
That cab only has an Up/Down shifter, but there is a software solution that will make it work just fine on the Sega 4 speed games.
Browse through the stickied driving cab example thread and see what others have done.
SegaOutrun
  • Last login:March 28, 2019, 03:02:05 am
  • Brakes are overrated
« Reply #3 on: July 29, 2013, 12:09:17 pm »
Given that the artwork is good and looks complete, I would pay upto 200 for mame( I would pay a bit more if I was going to make it rebuild it). The artwork alone would be $100 if you picked up an ugly cab. The issue here is that it is not gutted, which means that the seller will see it as an almost complete build and will probably ask too much assuming that you can just purchase the board.
