Author Topic: true 15 pin vga cable?  (Read 1481 times)
tony.silveira
  • Last login:February 18, 2026, 09:58:05 pm
    • my baby
« on: July 28, 2013, 01:52:51 pm »
hey guys,
been a while.  i finally have the motivation to get my swappable add ons going, star wars is done, next up super hang on handle bars.
my quick connect/disconnect was designed around a 15 pin vga cable.  but every cable i've cut into has less than 15 wires.  anyone know where i can get a true 15 pin/wire vga cable?  specifically, i need one male end and multiple female ends (for each of the add ons).
thanks all,
tony
chopperthedog
  • Last login:Today at 08:41:53 am
Re: true 15 pin vga cable?
« Reply #1 on: July 28, 2013, 02:25:35 pm »
I have 2 10' DB15 extension cables that you are more than welcome to for the cost of shipping. Each cable has a male and female connector and I can confirm each pin has a separate conductor.
good day.
nick3092
  • Last login:March 22, 2022, 03:57:28 pm
« Reply #2 on: July 28, 2013, 02:43:31 pm »
I recall running into the same issue like a year and half ago when wiring up a Jaguar to USB adapter, so I didn't have to cut the controller end off.  If I recall, they tied the R/G/B grounds to the main ground, so you have 4 common wires instead of 4 separate wires.  Probably to save cost, and/or make a slimmer cable.
I'm pretty sure I wound up using the "full size" (non-slim) cables from Monoprice.  I had originally ordered a slim for this project, and it had shared grounds.  So I wound up having to use the bulkier fill sized cable I had sitting around for something else.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10201#1020104
chopperthedog
« Reply #3 on: July 29, 2013, 05:05:04 pm »
Package sent and tracking pm'd.
good day.
