Author Topic: Monitor pattern generator  (Read 2621 times)
Ken Layton
  • Guru
  • Technician
« on: November 14, 2003, 12:58:01 pm »
A monitor pattern generator is a piece of test equipment that you use to check & align video game monitors. Generally they generate some basic colors and patterns like solid red, green, blue, & white fields and crosshatch, dots, & bars. Most pattern generators generate either negative or positive sync, but not both. Only more expensive (or custom modified) ones have switchable negative-positive sync output. There's a basic one on ebay right now as item number 3253736264. The price is average for these.
« Last Edit: November 14, 2003, 01:19:09 pm by Ken Layton »
Ken Layton
  • Guru
  • Technician
Re:Monitor pattern generator
« Reply #1 on: November 14, 2003, 01:14:06 pm »
Here is a picture of the one in the above auction. I believe this particular model generates composite negative sync judging by the harness.
« Last Edit: November 14, 2003, 01:16:28 pm by Ken Layton »
Ken Layton
  • Guru
  • Technician
« Reply #2 on: November 14, 2003, 01:26:00 pm »
When I worked for Capitol Amusement here in Olympia, Washington we had two pattern generators. One was this "Checker 12E" (www.computermonitor.com) which is a pretty good all purpose unit. See the attached photo. This one generates seperate positive horizontal and vertical sync.
The other generator I had was made by WICO and I eally loved that one cause it not only did color game monitors, but black & white ones as well. It generated positive sync, but I modified it for switchable positive & negative sync and I also built a cable for the negative sync.
