Author Topic: Backwards compatibility with Roms?  (Read 2050 times)
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
« on: November 12, 2003, 06:35:42 pm »
Maybe this is a dumb question, but I'll ask anyway. Why are some MAME roms, even if seemingly unupdated, not backward compatible?
Example: Download the latest crush.zip (Crush Roller) or crush2.zip/crush3.zip. Run it in MAME 0.59. Doesn't work! It says "missing crush.4a". How come it was removed, even if the rom crush.zip has been in mame since 0.1?
Re:Backwards compatibility with Roms?
« Reply #1 on: November 12, 2003, 07:27:46 pm »
I think the reason is usually either:
a) they found a better rom/dump
b) they moved some roms to different parent/clone set
c) some rom(s) were re-named.
I don't know but I suspect the one you mention was probably renamed somehow (?)  Try ClrMAMEPro on it, it will rename/re-arrange if possible to fix...
EndTwist
  • Arg.
« Reply #2 on: November 12, 2003, 09:08:28 pm »
I've tried ClrMamePro, and it doesn't see anything wrong with it. I'm using my "MAME 0.59" dat file I made using the exe.
