Author Topic: Can't Control Advancemenu w/ joystick in GA - cursor spazzing out  (Read 2666 times)
Spicules
  • Last login:July 29, 2017, 11:40:33 am
Using Groovy Arcade w/ updated GM
I enabled joystick use in Advancemenu through the manual config utility, setting joystick to "auto."
When I get to the menu though, the joystick keeps moving left.  I could almost control it, but it keeps moving.
I am using a madcatz TE fightstick.  I think the joystick is considered a "pov" hat or something.  Is there a setting I need to change to get it to work properly?
machyavel
  • Last login:December 25, 2016, 10:23:52 am
Re: Can't Control Advancemenu w/ joystick in GA - cursor spazzing out
« Reply #1 on: May 27, 2013, 03:32:31 pm »
Hello, I had almost the same issue (for me it was going up by itself) with a madcatz te ps3. I messed with settings and now it works. Well it still goes up when I launch advancemenu but as soon as I move the stick in any direcion it stops going crazy. Try to change the joystick type to sdl in advance.rc. I also changed the keyboard type to sdl.
Almost forgot: I leave the TE into LS position (the 3-position switch beside the home button)
« Last Edit: May 27, 2013, 03:35:35 pm by machyavel »
Spicules
« Reply #2 on: May 27, 2013, 10:44:27 pm »
That did it!
