Author Topic: Filling gaps  (Read 1324 times)
DHTech
  • Last login:November 29, 2014, 03:48:36 pm
  • Arcade Flashback
    • Arcade Flashback - Hand Made Custom Arcade Machines UK
Filling gaps
« on: May 17, 2013, 04:31:43 am »
Would you guys recommending filling the area where the MDF butts up, the MDF edge is butted at a slight angle and you get that sort of V grove, is this worth filling? The MDF is tight against each other a you can just about see a thin sliver of light.
Any recommendation would be good, Thanks, Jeremy
Unstupid
Re: Filling gaps
« Reply #1 on: May 17, 2013, 05:31:39 am »
Cut your wood at an angle so that there is no gap.
Re: Filling gaps
« Reply #2 on: May 17, 2013, 01:08:53 pm »
If it doesn't need to come apart again and you don't feel like redoing it just fill it with bondo.
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
Re: Filling gaps
« Reply #3 on: May 17, 2013, 01:24:39 pm »
if you already put them together and its too late to pull them apart to angle cut, just bondo it.
you can even first round the sharp edge with a sander for a smooth rounded edge.
JDFan
Re: Filling gaps
« Reply #4 on: May 17, 2013, 01:31:05 pm »
And if you don't want to buy BONDO just collect some of that sawdust (should be plenty of it  :laugh2: ) from the cutting and mix it in some wood glue and use that to fill in the gap and sand as needed once it dries.
« Last Edit: May 17, 2013, 01:33:06 pm by JDFan »
Re: Filling gaps
« Reply #5 on: May 17, 2013, 01:44:03 pm »
duct tape on the inside.
DHTech
  • Arcade Flashback
Re: Filling gaps
« Reply #6 on: May 17, 2013, 01:45:36 pm »
Nah don't want to bodge it  :laugh2:
DHTech
  • Arcade Flashback
Re: Filling gaps
« Reply #7 on: May 17, 2013, 01:46:03 pm »
Fill and sand it is  :)
