Author Topic: Sharp 19" with arcadeVGA and amp cable - Top portion of the screen is skewed  (Read 1409 times)
joenet
  • Newbie
  • Last login:May 13, 2013, 12:56:02 pm
Setup is
Atari Vindicators with Sharp 19" display. Manual says pin 6 is "Negative Composite Sync"
http://www.arcade-museum.com/manuals-monitors/Atari%20Monitor%20TM-304%201st%20Printing%20Sharp%2019in%20Color%20Raster.pdf
I have tried to connect an ArcadeVGA (2nd gen) to the arcade using the breakout cable / amp from Ultramarc.  The video looks perfect from the botton to about the last 10% of the top. The top 10% of the screen is skewed to the right or sortof looks rolled over.  I have tried all sorts of adjustments on the monitor with no luck.  Am I connecting the syn wire correct to the vga amp? I connected the pin 6 wire from the monitor to the syn connection on the amp.
« Last Edit: May 10, 2013, 07:15:58 pm by joenet »
