Author Topic: Recess USB Port  (Read 11853 times)
jabbathehut
  • Last login:May 08, 2013, 04:08:31 am
Recess USB Port
« on: May 07, 2013, 04:00:41 am »
Hi all,
Fairly new here but I'm tackling my first bartop, I've got the side panels cut out (At least for the most part, they may still need to be squared up a little, but that's another story). I'll get around to making a build thread one of these days hopefully once I've made more progress.
Since I was deprived as a child (Only owned an NES) I thought I'd make this arcade cabinet also emulate consoles, so I went out and bought USB controllers for N64, SNES, and even NES. *Shakes stick at Sega* :-P (Just kidding Sega... You're OK)
I figured it made the most sense to recess a hole into my the front panel of my arcade, and get a socket for a couple USB plugs. Does anyone know the best sockets out there, or if I'd be better of finding a couple male to female usb extenders and then throwing some bondo around it and then painting it.
If it makes a difference I am using 3/4 inch melamine coated particle board.
A quick amazon search revealed this: http://www.amazon.com/Clarion-CCAUSB-Extension-Cable-Integrated/dp/B001GXQMXE/ref=sr_1_2?ie=UTF8&qid=1367913281&sr=8-2&keywords=usb+socket
Seems to just be a cable... Not sure why it commands a $22 price tag... I may have access to some similar cables from where I work. (Thank goodness for employee discount.)
If anyone has done this I'd appreciate their input. Thanks ahead of time!
edekoning
Re: Recess USB Port
« Reply #1 on: May 07, 2013, 07:16:03 am »
Why not use something like I used on my cab: 'Neutrik NAUSB-W-B'? I bought them for about 6 euro a piece at arcadeshop.de.
Drnick
  • Plodding Through Life
Re: Recess USB Port
« Reply #2 on: May 07, 2013, 01:19:18 pm »
I second the Neutrik connections. They are the cleanest way that I know of to have USB Passthrough.
  • Last login:Today at 02:50:15 am
Re: Recess USB Port
« Reply #3 on: May 07, 2013, 09:13:37 pm »
+1 for the Neutrik NAUSB-W-B (black) or NAUSB-W (silver).
Neutrik also makes color base-plates, covers, and a mounting plate -- see the data sheet for more details.
On this side of the pond, you can get the feedthrus at:
Allied Electronics
Mouser
Focus Attack
and many other vendors.
Brian74
  • Yep... I built that!!
Re: Re: Recess USB Port
« Reply #4 on: May 07, 2013, 09:56:05 pm »
Allied Electronics
Mouser
Focus Attack
I have two of them.
Sent from my SGH-T989 using Tapatalk 2
jabbathehut
Re: Recess USB Port
« Reply #5 on: May 08, 2013, 03:25:58 am »
This is why you guys rock... That is PERFECT. I think I'd seen them used on some of the projects here, I just didn't know where to find them. Someone should make/sticky a thread for "random-knick-knacks-that-might-be-needed"™
Brian74
Re: Recess USB Port
« Reply #6 on: May 08, 2013, 04:05:36 am »
Before I got these, I took two buttons, removed the plunger, cut out the center and hot glued a short USB extension cord.
Unstupid
Re: Recess USB Port
« Reply #7 on: May 09, 2013, 03:49:31 pm »
Cheaper... Vertical solder mount USB connector, a router, and a steady hand  ;):
DLinkOZ
  • Last login:March 22, 2017, 08:12:46 am
    • The DaveCade
Re: Recess USB Port
« Reply #8 on: May 09, 2013, 05:24:30 pm »
Has anyone seen anything like the Neutrik that offers a safety catch?  I'd hate for a sugar-fueled nephew to accidentally unplug one of my guns, potentially causing me to go through and re-ID and set it up again.
Re: Recess USB Port
« Reply #9 on: May 10, 2013, 12:32:28 am »
One of the main reasons for the Neutrik is the ability to easily plug and un-plug.
Maybe you can use a nylon loop clamp as strain relief.
Clamp shown is too large -- get the smallest that will still close.
They also come in black and most Ace Hardware stores sell them individually instead of having to buy a bag of them.
Protip: Take the USB cable with you and try the clamps on for size.   :cheers:
DLinkOZ
    • The DaveCade
Re: Recess USB Port
« Reply #10 on: May 10, 2013, 01:14:56 am »
That actually is a pretty simple solution.  Perhaps even attaching a some sort of elastic/spring so that an accidental tug doesn't result in either a reconfig (as-is and the plug pulls out) or something broken (clamped down, the strain finds the point of least resistance).
Re: Recess USB Port
« Reply #11 on: May 10, 2013, 03:36:44 am »
Consider using velcro for warning/shock absorption/deceleration.
8" each of hook and loop in a Y-configuration should do the trick.
Attach the hook (black) part + to the cab and the loop (red) part + to the cable ~1 foot from the end.
When the cord is pulled, the the velcro will tear apart as the ~1 foot of slack is pulled straight.
nemesismachine
  • Last login:August 18, 2014, 11:44:04 am
Re: Recess USB Port
« Reply #12 on: June 04, 2013, 04:44:27 pm »
ebarlow99
Re: Recess USB Port
« Reply #13 on: June 05, 2013, 11:14:09 am »
pinballfreak
  • Last login:March 23, 2014, 12:51:11 pm
Re: Recess USB Port
« Reply #14 on: June 05, 2013, 08:31:54 pm »
shponglefan
Re: Recess USB Port
« Reply #15 on: June 05, 2013, 10:12:11 pm »
Can anyone confirm what hole size is needed for the Neutrik connector?  Based on the datasheet, am I right in that it's 24mm?  There are no units on the datasheet.
edekoning
Re: Recess USB Port
« Reply #16 on: June 06, 2013, 02:36:32 am »
24 mm is correct
Re: Recess USB Port
« Reply #17 on: June 06, 2013, 10:56:03 am »
Mr. Micrometer sez the hole needs to be at least 0.925" for us non-metric types.
The mounting plate is 1.022" wide.
keilmillerjr
  • Web Developer.
Re: Recess USB Port
« Reply #18 on: June 11, 2013, 01:54:41 am »
Do you happen to have a link? Come in type A female? These look perfect for a professional look.
Re: Recess USB Port
« Reply #19 on: June 11, 2013, 12:54:16 pm »
Maybe something like this would work.
keilmillerjr
  • Web Developer.
Re: Recess USB Port
« Reply #20 on: June 11, 2013, 01:25:13 pm »
I was able to find these, but at 22.95 a piece, they are definitely out of budget. They look nice though. GTC makes them.
Still looking for those usb connectors with the recessed bolt hole tabs.
JDFan
Re: Recess USB Port
« Reply #21 on: June 11, 2013, 02:44:25 pm »
Could use a wall outlet plate similar to these for about $5 or less - ( http://www.newegg.com/Product/Product.aspx?Item=9SIA1NV0T67856 )
I went with a couple spares like these :
 I had from an old case that fit into a back MOBO adapter slot and made mounting holles in the aluminum channel I had to use on the back of the cabinet (resizing the bartop plans didn't leave room inside for the PSU I had so created an opening so the back would fit) you can see them in this pic :
« Last Edit: June 11, 2013, 02:51:54 pm by JDFan »
Unstupid
Re: Recess USB Port
« Reply #22 on: June 11, 2013, 03:12:20 pm »
Here is the ones I used: http://www.digikey.com/product-detail/en/USB-B1SMVSW6/ED2993-ND/2677754
Type A are usually flanged at the end so I couldn't use those with a wood through hole.  I guess if you cut a metal mounting plate you could make it work but I find it easier to just but the A-B usb cable.
jdbailey1206
Re: Recess USB Port
« Reply #23 on: June 13, 2013, 08:25:20 am »
Allied Electronics
Mouser
Focus Attack
I have yet to install mine but it seems the easiest route to measure and drill a hole and throw these bad boys in.
stripe4
  • Last login:May 03, 2026, 02:33:27 pm
    • forum.arcadecontrols.com/index.php/topic,129541.0.html
Re: Recess USB Port
« Reply #24 on: June 13, 2013, 10:35:58 am »
BTW, Farnell carries Neutrik products, too.
keilmillerjr
  • Web Developer.
Re: Recess USB Port
« Reply #25 on: June 15, 2013, 07:56:10 pm »
So, I coughed up the money for 2 of the Clarion CCAUSB units. I am very impressed with the quality. I like that they have a rubber cover to soemwhat hide them. I defiantly think they are over priced. With the two of these, I can plug in a mouse and keyboard for admin, and possibly some light guns.
http://www.amazon.com/gp/aw/d/B001GXQMXE
Off topic, but is there any good lighthun games that might work with 3.1 i3 4gb?
