Author Topic: Question Regarding Don's Hyperspin Tools error  (Read 3194 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: March 30, 2013, 05:45:27 pm »
Does anyone know how to fix this error:
"The application failed to initialize properly (0xc0000135). Click on OK to terminate the application."
It is Windows xp and the latest version of Don's Hyperlist tools 4.0.12
Yourname942
Re: Question Regarding Don's Hyperspin Tools error
« Reply #1 on: March 31, 2013, 02:47:28 pm »
Does anyone know what that error means on Windows Xp? (or how to get it to work) Thanks.
Drnick
  • Plodding Through Life
« Reply #2 on: March 31, 2013, 04:33:12 pm »
Have you got Net Framework 1.1, 2.0 & 3.5 installed.
I can't remember which version it uses off the top of my head.  I am currently rebuilding a machine and to be on the safe side installed all the above.  I didn't bother with 4 as that seems to want SP3 installing and that will break FFB on my wheels. 1.1 & 2.0 will install with XP SP1, 3.5 needs to have SP2 and Windows Installer 3.1
Yourname942
« Reply #3 on: March 31, 2013, 10:19:27 pm »
What is SP2 3 and 1 again?
I don't think that he does on the XP. I only tried to install 4 bc I couldn't find earlier releases available.
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #4 on: April 01, 2013, 09:37:56 am »
Make sure to do a Google next time as this specific issue is discussed on Don's Hyperspin tools page:
When try run the Dons HyperSpin List Generator.exe appear the following message of error:
Error 0xc0000135
The solutions is install the client net framework ( http://go.microsoft.com/fwlink/?linkid=182804)
Found at: http://honerbrink.com/?page_id=14 (Search for 0xc0000135 and you'll find the section)
You basically need .NET 4.0 from the article.  They recommend Service Pack 3 for Windows XP but I can't find anything that says it won't work if you don't have SP3.
