Author Topic: Switchres behaves odd with some games  (Read 2694 times)
ckong
  • Last login:October 19, 2020, 06:48:09 pm
  • Retro Games forever!
« on: March 28, 2013, 04:11:04 pm »
I'm running the latest Groovymame 0148u2 build for windows and I noticed something odd with some games, like Frogger or mooncrest.
At first switchres creates the crorrect modeline, but within a blink of the eye a secoden modeline is created, wich gives a terrible small and flickering image. But for instance Zaxxon and Galaxian, which use the same resolution as Frogger, do play corrcetly. See the attachment for more info. Why is that and how to solve it? I have tried different 'monitors' in the mame.ini, like generic_15, arcade_15 and ms929.  Oh, and I am using a vertical orientated monitor.
« Last Edit: March 28, 2013, 04:14:39 pm by ckong »
dgame
  • I am no Jedi
Re: Switchres behaves odd with some games
« Reply #1 on: March 28, 2013, 04:35:40 pm »
post the results of: gcmame -v frogger
you can put the results in a text file with: gcmame -v frogger > frogger.txt
ckong
« Reply #2 on: March 28, 2013, 05:20:52 pm »
yeah, should have done that right away.  :banghead:
anyway, I attached the txt file for Frogger and as a reference also for Galaxian
ckong
« Reply #3 on: March 28, 2013, 05:52:42 pm »
OK, I found the reason for the strange behaviour. It has to do with the artwork folder in my mame folder, in which all the 'in-game' artwork files are. Although I had disabled the use of artwork in the mame.ini, and even did put a .; for the artwork path, the Mame.exe did still call it.
So instead of deleting it, I renamed the artwork folder in 'artwork backup' and now everything is cool. Frogger, Mooncrest and probably others play as they should, with the correct switchres behaviour.  :applaud:
« Last Edit: March 29, 2013, 02:02:08 am by ckong »
