Author Topic: OutRun & Pole Position Gears  (Read 2702 times)
EssexMame
  • Last login:March 31, 2026, 06:36:41 am
  • Mame Weekender
« on: March 18, 2013, 09:28:59 am »
On Outrun and Pole Position, if I have bezel=1 then I see an image of the gear lever (Pole Position) and HI/LO indication (Out Run).
how do I see these without bezel being on - i.e. how do I get an on-screen indication of what gear I'm in (which I'll need to play the game until I've a physical gear lever which makes it obvious)?
arquillos
  • Last login:June 05, 2026, 04:21:13 am
Re: OutRun & Pole Position Gears
« Reply #1 on: March 19, 2013, 11:27:25 am »
Hi!
   I´ve got the same question!
   I have a nice 16:9 Outrun Bezel and when I use it I can´t get the Hi/Lo image...Is this Hi/Lo image imcompatible with Bezels? Is is another "invisible" Bezel?
Thank you in Advance!
EssexMame
  • Mame Weekender
« Reply #2 on: March 19, 2013, 12:56:31 pm »
http://forum.arcadecontrols.com/index.php?topic=97407.0
This helps (a bit) - its seems to be part of the "overlay", so overlay=1 in the artwork section of mame.ini? Not sure where the images come from though.
Also, maybe removed in mame 0.148? I don't think I've seen them since I've upgraded (though I've had bezels etc. off too for a while until recently investigating this.
  • Last login:Today at 12:33:17 am
« Reply #3 on: March 19, 2013, 04:24:02 pm »
Some artwork in mame is actually built into the exe, this is the case for the high/low shifter in a lot of games.
I suggest you contact Mr. Do over at mameworld.  He is the caretaker of all things artwork.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: March 20, 2013, 02:50:41 pm »
Not since the late .80s or so. They're artwork-artwork.
-Banned-
« Reply #5 on: March 20, 2013, 07:29:08 pm »
No there not.... you have that OPTION, but the basic shifter is internalized.  I'm running .148.... just fired it up, I have the option of turning on a shifter in the bottom left and bottom right corners.  Some of the drivers have the internal shifter, some don't.
After downloading the artwork file which contains a custom shifter image.
It looks like this for the shifter section of the lay file:
Code: [Select]
<bezel element="shifter" inputtag="IN0L" inputmask="0x02">
<bounds x="4050" y="2054" width="700" height="781" />
</bezel>
See the inputtag and inputmask sections?  Those are going to be unique for each game.  So like I said, contact Mr. Do and stop arguing.  ;)
