Author Topic: Mounting Sony PVM in Arcade Cab  (Read 1823 times)
Hamster
  • Last login:February 08, 2014, 12:21:44 pm
« on: March 16, 2013, 06:28:28 pm »
I have a 19" Sony PVM that I'd like to use in a Joust cab . How difficult will it be to use the Sony PVM in that cab ? Does the mounting hardware on the Sony line up with the standard arcade monitor setups ? Thanks ,
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: Mounting Sony PVM in Arcade Cab
« Reply #1 on: March 17, 2013, 05:27:06 am »
i dont say its impossbile , buts its not worth the effort. sonys broadcasting monitors are packed with pcbs and all kind of stuff. it would be difficult to dismantle it all and rebuilt it inside a cab . i suggest building something around such a beast or check the market for an old 50-60 hertz ( usually black cased ) sony tv set. old sony trinitron tvs are almost as good as theire studio brothers without most of the downsides . usually the chassis are small and plug n play style . a 10 year old child could talke it apart in less than 15 minutes . a con against sonys in arcade cabinets is the trinitron shape of the tube , meaning the curvature and mounting is far from mainstream . u have to adapt the mounting frame , bezel etc.  if u are are able to aquire a sony in good shape with few miles on the tachometer ( grandma or bedrooms tvs ) and adjust it properly , u will be rewarded with very good lowres image quality .
« Last Edit: March 17, 2013, 05:29:17 am by apfelanni »
Hamster
« Reply #2 on: March 17, 2013, 01:08:12 pm »
Ok Thanks , I won't bother . I was trying to save money because I have a PVM sitting here , sounds like a hassle .
