Author Topic: Kinda disappointed with the MAG-Stik Plus(8-way)  (Read 5289 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« on: March 16, 2013, 09:27:42 am »
Hello all,
Finally got a chance to really play with my 2 MAG Stick Plus joysticks I bought from another member here as my brother-in-law came over to play some MK2.  It was a blast regardless but we really started to notice the flaws with these joysticks on 8-way mode.  In short they are just to touchy.  If I feel like I am pulling down on the stick it goes Left+down or Right+down.  Try to push up to jump and he goes Right +up.  I tried adjusting little bars on the bottom of the joystick to no avail.  If I play in 4-way mode they work really good.  I know this because without me knowing I was running in 4-way for the first week I was testing.  Went through the menus of GameEx without any issues(you know going UP and DOWN through the menus)  Well I knew I had someone coming over last night and wanted to just test everything hen I noticed my #2 was in 8-way and my 1st Player was in 4-way.  I change it to 8-way and I have a very hard time even getting through the menu on GameEx.  If I compare the bottom to a $9 joy I bought before I got the "deal" from the person on here I can see the $9 one just has so much more room between the switches and the handle/rod which makes them less touchy(just a guess as I have not connected it up)...than the MAG Stik PLus.  After we were done remember MK I changed #1 back to 4-way and it seems fine(touchy at spots)...but this really hurts my Fighting/Sport games.
Anything I can do to fix this?
Are these joysticks not as "new" as the seller proclaimed?
Am I doing something wrong?
Thanks,
Rich
Richie_jones
  • Last login:February 19, 2026, 01:59:01 am
« Reply #1 on: March 16, 2013, 10:02:46 am »
I have the j sticks from ultimarc, I don't like them either.  Far to much travel between switches and hit and miss when asking for corner inputs...it's a shame but to change them I'd need to redo my cp art as I've covered the screws over..
chopperthedog
  • Last login:September 18, 2026, 12:10:07 pm
Re: Kinda disappointed with the MAG-Stik Plus(8-way)
« Reply #2 on: March 16, 2013, 12:24:31 pm »
Sounds like you two should trade stiks :P
Imo using the magstik on fighters is like driving with racing slicks in the snow. I Just started using a pair of magstiks (with ball tops) on a multiwilliams type panel and I have no complaints with 8 way mode on games like smashTV, robotron, 1944 and others since they are replicating the short throw of a wico. But I also know that I would never take out the pair of happ competitions out of my fighter cab and replace those with magstiks. The magstiks are a great piece of hardware when used with the right games.
good day.
rtkiii
« Reply #3 on: March 16, 2013, 01:19:28 pm »
So this is more of a preference thing than a defect with the joysticks?
Drnick
  • Plodding Through Life
« Reply #4 on: March 16, 2013, 04:06:18 pm »
Unfortunately yes,  I had zippy's in my control panel originally and they were OK for the classic 4 ways and they were pretty good for fighters, but for SHMUPS they just didn't cut the mustard.  I figured that fighters were the least played of all types so I swapped them out for Magstick Plus.
Endprodukt
  • Last login:September 08, 2026, 05:50:12 am
AW: Kinda disappointed with the MAG-Stik Plus(8-way)
« Reply #5 on: March 16, 2013, 05:12:48 pm »
I love zippys for shmups. With a little modding to the spring and actuator it's a good all round joystick
j2obin
  • Last login:March 12, 2015, 02:10:20 pm
« Reply #6 on: March 17, 2013, 11:09:07 am »
What mods do you do?  I am having some problems with spring binding and popping that makes them annoying to use.
Hoping to cure this.
For the OP about mag sticks.  I don't have anything to suggest for fighters.  I use them on my sit down cocktail for classic games and shooters and I really like them for that application.  I use Happ sticks for fighters.  Thinking of using Seimitsu in the bartop kit I ordered from HaRuMaN.
« Last Edit: March 17, 2013, 12:22:48 pm by j2obin »
Endprodukt
« Reply #7 on: March 17, 2013, 01:46:06 pm »
I bend the spring to give it  a better tension. I used three layers of heat shrink tubing around the thin side of the actuator to give it a smaller throw and used 4 layers of electric tape around the thick side of the actuator so the switches get activated much faster.
rtkiii
« Reply #8 on: March 17, 2013, 06:50:33 pm »
I ended up throwing in the $9 Super Joystick I bought and it seems to respond so much better to MK and whatnot in early testing.  Sometimes more expensive is not better.
Endprodukt
« Reply #9 on: March 18, 2013, 04:11:10 am »
For mk I'm all over competition sticks.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #10 on: March 20, 2013, 02:33:51 pm »
That hasn't changed since their inception. That's about all they're good for. Come to think of it, they games were probably designed to respond to them.
-Banned-
Endprodukt
« Reply #11 on: March 20, 2013, 08:06:40 pm »
Probably, but I got really good with them and after years and years I was so used to them I could barely use other sticks. I still can't get used to my servo sticks but feel like I have to as they're not that cheap :)
rtkiii
« Reply #12 on: March 20, 2013, 08:37:56 pm »
I actually found a setting in GameEx that fixes the menu issue I was having with the 8-way MAG Plus.  Still a little loose in MK but I can at least manuever the menus  :)
