Author Topic: Wiring Up Coin Mech  (Read 4975 times)
mitze90
  • Last login:March 16, 2013, 04:51:04 am
Wiring Up Coin Mech
« on: March 13, 2013, 09:37:46 am »
Hello, Ive had a MAME Candy Cab for a few years now and I recently decided to get a coin mech workimg with it. On closer inspection it has a coin mech which is just missing the chute that drops the coin in to the top, which im guessing shouldnt be to hard to make.
Now my problem, I know with a Mars 111 its just the simplish matter of giving it power and a ground from the pc and a wire to the ipac coin terminal. But ive got Cashflow 115 dfx and im unsure of where to connect the wires...
« Last Edit: March 13, 2013, 09:51:14 am by mitze90 »
  • Last login:April 19, 2026, 07:24:05 pm
Re: Wiring Up Coin Mech
« Reply #1 on: March 13, 2013, 09:59:53 am »
I cant really help you, except to post this link I found on the net:
http://www.namco.co.uk/PDF-manuals/mars-manuals/126-129_User_Guide.pdf
That looks like a pretty complicated setup, compared to the simple coin mechs with just one micro switch.
mitze90
« Reply #2 on: March 13, 2013, 10:25:15 am »
Yeah I was trying to understand that manual yesterday  ;D which is what brought me to here.
After watch this video on wiring the Mars 111...
And looking at that manual (page 12) Im pretty sure all i need to do is attach the wires to the routing plug at pins 1 (ipac coin), 11 (12v from pc) and 12 (ground from pc). But Id rather not do it on the off chance Im right.
« Last Edit: March 13, 2013, 10:29:02 am by mitze90 »
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
« Reply #3 on: March 14, 2013, 05:38:39 pm »
thats my video  ;) hope it helped,
bluemini17
dgame
  • I am no Jedi
« Reply #4 on: March 14, 2013, 11:39:55 pm »
The Ipac expects a 5 volt coin signal.
If that coin mech has a 12 volt signal put a 5 volt Zener diode between the ground and coin signal on the Ipac.
For an explanation read the bottom of this page: http://www.ultimarc.com/controldiags.html
mitze90
« Reply #5 on: March 15, 2013, 08:44:24 am »
Hmmm spoke to the guy at Swallow Amusements and he said I need a credit board?
Groundstate
  • Last login:November 13, 2022, 07:59:18 am
« Reply #6 on: November 13, 2022, 07:59:18 am »
Did you ever get this working?
I am in the exact same position with mine and need a little guidance on getting it working.
