Author Topic: Coin Door light - options?  (Read 1294 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: March 09, 2013, 09:02:47 pm »
Hi folks:
I picked up an old cabinet that has a coin door, but it's been gutted.  I'm in the process of rebuilding it.
I'm curious to know what options I have in terms of wiring some lights to the coin door to illuminute the 25 cents logo.  I'm thinking of a JAMMA board, and not a PC, so the power will need to come from the power supply of the PCB.
lilshawn
  • Last login:April 20, 2026, 02:17:22 pm
Re: Coin Door light - options?
« Reply #1 on: March 09, 2013, 09:56:50 pm »
most jamma harnesses in cabinets are already wired for bulbs to light up the coin slots...so it should already have a wire going there supplying 12 volts.
if you don't have sockets, you can get "wedge" style  holders that just clip on to the coin runner on the top or on a tab built onto the top or  you can retrofit one and attach with a screw (depends on your door style and how old it is.)
Coin Control tab style are  Happ number 891-1117-00
runner style lampholders are Happ number 42-0351-00D
micahman33
  • Last login:September 04, 2024, 03:56:19 pm
« Reply #2 on: March 12, 2013, 11:59:53 am »
Honestly, I didnt even mess with the original lighting harness even though my coindoor came with one. I bought a bunch of USB powered flex-lights off amazon and use that to light both coin buttons and my marquee. They are low power consumption/low heat, required no fancy wiring, and look great.
mcseforsale
  • Creepy Mario Dude
« Reply #3 on: March 12, 2013, 01:04:38 pm »
Some of the older coin doors are running 14 volt bulbs.  You may have to replace those with automotive wedge bulbs and that's it.
AJ
ids
  • Fighter Captured
