Author Topic: Killer Instinct 2 RGB/fade  (Read 1845 times)
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« on: February 26, 2013, 04:24:46 am »
Buddy of mine has an all original KI2 cab and the video has turned tits up. Powersupply blew about 6 months ago and he replaced it with new OEM.
After the install, the image has turned to greyscale and lost most of its luminosity (native brightness is close to 30%).
I thought it might need a new 8-liners chassis (which I've installed before on my own Midway cab), but wanted to run it by the forum pros (Ken?) before I tell him to spend $100 on something he doesn’t need.
Thoughts? If someone has a few troubleshooting tips to throw my way I'd appreciate it!  :dunno
Signature tags are dumb.
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
Re: Killer Instinct 2 RGB/fade
« Reply #1 on: February 26, 2013, 08:04:23 am »
Have you tried any other games boards in the cabinet and is the jamma harness providing the right voltage to the pcb?
M3talhead
« Reply #2 on: February 26, 2013, 08:09:00 am »
No other boards on hand to test with and no schematic either. What should the HV and RGB read?
« Reply #3 on: February 26, 2013, 08:12:37 am »
Where are you at? If you're local to me I have a jamma board you can use to test
M3talhead
« Reply #4 on: February 26, 2013, 09:35:12 am »
Pensacola, FL.
« Reply #5 on: February 26, 2013, 11:27:57 am »
Pensacola, FL.
welp best I can do is ship you a board and you just ship it back to me. I use a horseshoes game PCB cause its super tiny, unless someone one closer to you has one. LMK
adidas1984x
« Reply #6 on: February 27, 2013, 09:01:45 am »
how did the monitor look before i have a similar issue with my wg u2000 that is dim on some game boards but on my tekken boards its bright and crisp
