Author Topic: Paint Aimtrak Sensor Bar  (Read 1152 times)
maffewl
  • Last login:June 05, 2020, 03:11:44 pm
« on: February 02, 2013, 11:34:08 am »
Can I tape off the LED's and spray paint the Aimtrak Sensor Bar?  If it was black it would blend in much better with my cab, but I wasn't sure if this would mess anything up with the sensor bar itself... any help would be appreciated.
Re: Paint Aimtrak Sensor Bar
« Reply #1 on: February 02, 2013, 02:57:22 pm »
IIRC you can remove the cover completely and paint it separately.  I would do that rather than hassle with taping off the LEDs but sure, you can paint the cover.
« Reply #2 on: February 02, 2013, 03:34:25 pm »
Only recently has it included a cover.  Mine is just some LEDs on a PCB.
I doubt there is anything on the PCB that would be damaged as long as the paint isn't conductive.
Andy would probably sell you a cover is you emailed him.
ArcadeGuns.com used to sell a cover (before Ultimarc had them), but it doesn't look like they sell separate parts anymore.
maffewl
« Reply #3 on: February 02, 2013, 08:33:08 pm »
Thanks for the help guys... I figured out a way to hide sensor bar without painting it, however, I just couldn't get the Aimtrak to work right so I'm giving up on it.  I appreciate the help though!
