Author Topic: Where to find a translucent clear trackball?  (Read 2145 times)
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« on: January 23, 2013, 09:19:21 pm »
I'm looking to find a 3" translucent trackball that will glow white or clear. I can't seem to find anything accept blue, orange, green, etc. Anyone have any suggestions? I can't be the only one looking I hope!
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
Re: Where to find a translucent clear trackball?
« Reply #1 on: January 23, 2013, 09:23:43 pm »
Contact juggling ball - 3" is a pretty standard size.  They are pretty durable too, and when you're not using it as a trackball you can jazz out and pretend you're Jareth from Labyrinth.
http://www.seriousjuggling.com/acrylic-balls-contact-juggling.htm
All kinds of colors available - amazon has them too
http://www.amazon.com/Ultra-Clear-Acrylic-Contact-Juggling/dp/B0042UBUZI
stpcore
« Reply #2 on: January 23, 2013, 09:25:49 pm »
Has anyone used these with success? Are they weighted the same? Gonna put it in a Golden Tee and I don't want to be disappointed with it. Thanks for the suggestion.
« Reply #3 on: January 23, 2013, 09:37:47 pm »
Never used one.  Let's see, suzohapp carries a 3" clear replacement ball for $60ish
http://na.suzohapp.com/trackballs/950029xx.htm
It doesn't have a weight listed but I'm sure with some research you could figure it out then compare the two since we know the juggling ball is 241grams from amazon and 270ish from the juggling website I linked.  Then you could just compare relative densities and ascertain a conclusion from that.  Did you try googling?
stpcore
« Reply #4 on: January 23, 2013, 09:43:36 pm »
I checked all of the vendors here and ebay and didn't find anything. Yes I did check google first. Thanks. I will order from Happ. I normally don't like to order direct from them due to pricing they offer.
« Reply #5 on: January 23, 2013, 09:52:06 pm »
Try divemaster, he might have one for a bit cheaper.
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« Reply #6 on: January 26, 2013, 02:54:47 am »
I used one(3" juggling ball) in a build....perfect fit, but the translucent ones aren't lighting friendly.  The trans blue ball I used blazed to the point the led I had installed was unusable.  It was a 5v led, but maybe if you had more control of the light output it would work.
But if you're not looking for a colored translucent ball they'll work real well.
stpcore
« Reply #7 on: January 26, 2013, 09:58:01 am »
I actually noticed that Happ sells a translucent WHITE 3" trackball replacement for under $30.  That will work perfect for Golden Tee / PGA Golf Machines.  Thanks for all the help.
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
mgb
  • Last login:May 12, 2026, 07:50:55 am
  • North East, US
« Reply #9 on: January 26, 2013, 01:54:15 pm »
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=74&products_id=273
+1
if you're looking for white, why not use the iceball? Thats what I have and I love the look of it.
Brian74
  • Yep... I built that!!
« Reply #10 on: January 26, 2013, 04:21:46 pm »
I have the iceball, its nice. My buttons are clear, so I am looking to swap mine out too.
stpcore
« Reply #11 on: January 26, 2013, 10:23:03 pm »
I think I will give it a try. Thanks everyone.
