Author Topic: MAMEWAH Setup - MW Users please read  (Read 10284 times)
« on: October 26, 2003, 05:41:33 pm »
David Butler has kindly written a great utility for MAMEWAH.  I have not given it any extensive testing, but it seems to work very well...
It allows easy configuring of everything in MAMEWAH, and can even read old config files etc.
Please give it a try: http://uk.geocities.com/david.butler4@btinternet.com
I'll be adding a link from my site shortly...
Edit by SirP:  Added url tags.  Correction, tried to add url tags, even that didn't help.  Sorry folks, you have to copy and paste the link.
« Last Edit: November 08, 2003, 05:05:22 pm by SirPoonga »
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:MAMEWAH Setup - MW Users please read
« Reply #1 on: October 26, 2003, 06:32:13 pm »
link broken?
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #2 on: October 26, 2003, 07:08:23 pm »
nah, the board just didn't like the @
try copy-pasting the whole URL.
papaschtroumpf
  • Have a Cow!
« Reply #3 on: October 26, 2003, 10:57:51 pm »
"Run-time error 5" Invalid Procedure Call or Argument
Oh well, maybe I'll wait for the next version. Does the author monitor these pages?
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
« Reply #4 on: October 27, 2003, 09:47:58 am »
Yes I do every so often. :)
Try downloading v 0.72
« Last Edit: October 27, 2003, 09:49:01 am by DBut »
papaschtroumpf
  • Have a Cow!
« Reply #5 on: October 27, 2003, 07:39:20 pm »
Nope, same error in 0.72.
Running XP Pro.
and welcome to the forum.
« Last Edit: October 27, 2003, 07:39:48 pm by papaschtroumpf »
DAmnb
  • Last login:July 28, 2011, 03:35:40 pm
  • R-Type for president!
    • TheGameCollector
« Reply #6 on: October 28, 2003, 04:40:22 am »
Got the same problem, doesnt seem to be XP friendly  :'(
« Reply #7 on: October 28, 2003, 05:11:56 am »
Odd, it worked for me  ???
DAmnb
    • TheGameCollector
« Reply #8 on: October 28, 2003, 10:57:35 am »
Could it be that we are missing any files?
What is this baby made with?
papaschtroumpf
  • Have a Cow!
« Reply #9 on: October 28, 2003, 11:08:18 am »
Yeah, maybe we're missing VB runtimes or something. I seem to have problems with a lot of VB apps, but again lots of others work flawlessly.
« Last Edit: October 28, 2003, 12:10:12 pm by papaschtroumpf »
« Reply #10 on: October 28, 2003, 11:15:12 am »
Well it *should* have all the required files included in the setup...
Maybe because I had installed a previous version a while back (or indeed bcause I have VB), I already had the required files.  I am not sure what it is programmed in tho...
Dave Butler
    • MAMEWAH Setup
« Reply #11 on: October 28, 2003, 12:28:01 pm »
It's programed in VB. And I have Windows XP.
But I appear to be having a bit of truoble with the Installer. I am trying to get it sorted out, so there sould be an updated Installer that works within the next few days.
As far as I can tell all the DLL's etc are packaged with the Installer. But as this is my first program that I have released It may take me A while to get it working right.
DAmnb
    • TheGameCollector
« Reply #12 on: October 28, 2003, 06:30:22 pm »
Well im looking forward to your next release then, looks like a great program.
« Reply #13 on: October 28, 2003, 07:20:18 pm »
It is - I think a lot of you guys will like it  :).  It is a very visual way of configuring, without entering MW or editing text files.  The fact that old CFG files can be read/updated will be the icing on the cake  :)
Dave Butler
    • MAMEWAH Setup
« Reply #14 on: November 02, 2003, 07:32:51 am »
Right Lets try again. ::)
Updated prog to ver 0.7.3. Hopefully this will work a bit better.
Should have fixed a few bugs in program and updated Help file.
Let me know if it works or not.
I have installed on Win 98se and it works.
Started to work on Filter editor. Which is going to be fun to do :-\
Safron
  • Last login:September 27, 2004, 12:00:41 am
« Reply #15 on: November 02, 2003, 01:39:12 pm »
No luck yet.
I have XP Pro and am getting a module not found error.
Dave Butler
    • MAMEWAH Setup
« Reply #16 on: November 02, 2003, 02:54:25 pm »
Has anybody actually got the program to run.
All the errors appear to be on XP Pro.
I have XP Home and it worked on 98se, so why does it not work with XP Pro?
Perhaps I should go back to Package And Deploy wizard in VB?
Also have a question. Im not sure if anybody will find this usefull or not but i am thinking of putting a ROM Suffix renamer program in with my set up program. It's not much but I find it usefull for Genesis and snes files.
« Last Edit: November 02, 2003, 03:14:36 pm by DBut »
eightbit
  • My cab is never done...
« Reply #17 on: November 02, 2003, 03:55:55 pm »
Doesn't work on my xp pro either.
« Reply #18 on: November 02, 2003, 03:57:50 pm »
I'm using XP Home, and it works.  But I can see no reason why it shouldn't work on Pro either :(
Dave Butler
    • MAMEWAH Setup
« Reply #19 on: November 03, 2003, 04:38:53 pm »
May have found out the problem with program?
I have used a dll that is not redistributale (fm20.dll) :(
Basically the dll is installed as part of MS Office and to use it you need it to be installed on your system prior to installing MAMEWAH Set-up.
The good news is that you can freely download a prog that installs it from Microsoft (Microsoft ActiveX Control Pad)
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnaxctrl/html/cpad.asp
If this does not fix the problem then I have no idea what the problem is. ???
papaschtroumpf
  • Have a Cow!
« Reply #20 on: November 03, 2003, 05:06:22 pm »
Do you need ActiveX control PAd installed or just the DLL?
I'm the paranoid type and I don't like the sound of that ActiveX control.
I have a version of office on the computer I tried this on, but it's a fairly old verison (2000 Pro?). I'll check if fm20.dll is installed.
DAmnb
    • TheGameCollector
« Reply #21 on: November 03, 2003, 05:07:48 pm »
Just installed the dlls and now MWSetup seem to work fine!
Time for some hardcore testing  ;D
eightbit
« Reply #22 on: November 03, 2003, 05:30:57 pm »
I already had that Dll on my XP pro box. Here is the message I immediately get when I try to launch it.
Safron
« Reply #23 on: November 03, 2003, 07:07:48 pm »
I also have fm20.dll on my XP Pro box.
I get a "Red X" error box that says:
System Error &H8007007E (-2147024770). The specified module could not be found.
<edit> This must be an old version of fm20.dll.
I just installed the ActiveX patch and MAMEWAH Setup is working great.
Looks good so far.
Thanks DBut!! </edit>
« Last Edit: November 03, 2003, 07:28:00 pm by Safron »
DAmnb
    • TheGameCollector
« Reply #24 on: November 03, 2003, 08:32:53 pm »
Been trying out the program for a while now and I must say: Great Job! Its a great tool for a great frontend! d:^_^:b (thats two thumbs up incase you didnt know ;) )
eightbit
« Reply #25 on: November 03, 2003, 09:38:55 pm »
I installed the active pad control and still no work on my xp pro.
papaschtroumpf
  • Have a Cow!
« Reply #26 on: November 03, 2003, 10:18:19 pm »
I already have fm20.dll v 2.1.9922.1 on my machine (running XP Pro) and I get the same message as eigthbit. I haven't tried installing the ActiveX control but from previous posts it seems like a no-go.
Do we need a specific version fothe dll?
Dave Butler
    • MAMEWAH Setup
« Reply #27 on: November 04, 2003, 06:45:29 pm »
eightbit and Papaschtroumpf.
I have no idea why you are getting the runtime error 5.
I can only sugest a few things to try to see what happens.
1. MAMEWAH Set-up uses the systems regisry to store info. If the program doesn't dispaly anything apart from the error (A window should appear asking where MAMEWAH.EXE is installed) then there shouldn't be anything in the resitry, check 'HKEY_CURRENT_USER,Software,VB and VBA Program settings,MAMEWAHSetup' if MAMEWAHSetup exists you could try deleting it (It should not do any harm).
2. In the MAMEWAH folder move your CFG files to a back up folder and run MAMEWAH as though it was a new install, so that you get the blank config files, and try running Set-up to see if you still get the same error. But if you do not get the first window to display I can't see this being the problem.
If none of the above work the problem is in the first few line of my code and all that happens is the sound is setup and the tab strip for the differant pages.
I'll keep diging to see if I come up with anything else ;D
DAmnb
    • TheGameCollector
« Reply #28 on: November 04, 2003, 08:31:08 pm »
Did you uninstall and then reinstall MWSetup after you installed the dlls?
Dave Butler
    • MAMEWAH Setup
« Reply #29 on: November 10, 2003, 05:26:25 pm »
Version 0.7.4 Released
I have added an update (EXE only) to my site so you don't have to download the whole installer again. Unzip and put into MW Setup folder.
Added filter Editor.
Added code to do Game list for ZINC.
Found a few more bugs. >:(
See News on my site for info
eightbit
« Reply #30 on: November 10, 2003, 07:19:56 pm »
I was one of the people having trouble getting it to work. I tried the new version and it works great for me. This is really cool it will help you configure options easily that you probably didn't even know were there.
I'm running xp pro.
papaschtroumpf
  • Have a Cow!
« Reply #31 on: November 10, 2003, 08:22:26 pm »
I'll give it a try too then. I didn't see anything in the post about addressing the problem we were having, but now it's worth giving it a try (also my cab computer is finally up after upgrades so I can try it on the real one instead of my laptop).
eightbit
« Reply #32 on: November 10, 2003, 09:31:53 pm »
I haven't tried it on the real cab. It works on my laptop though and since I was getting the exact same error on both my guess would be that it should work. Its really cool and exposes a bunch of features that I didn't even know were there.
papaschtroumpf
  • Have a Cow!
« Reply #33 on: November 10, 2003, 10:25:52 pm »
works for me too!
Cool!
Haven't played with it much yet but it looks pretty complete.
Thanks DBut!
papaschtroumpf
  • Have a Cow!
« Reply #34 on: November 12, 2003, 01:06:17 pm »
Works on my cab just fine now, so whatever the problem was, it's fixed.
The app doesn't quite fit in a 1024x768 window, I find that kind of annoying, but that's very minor.
Dave Butler
    • MAMEWAH Setup
« Reply #35 on: November 12, 2003, 04:38:06 pm »
I Know the window is a bit large but you can resize the window and use the scroll bars.
It was that or have a dozen pages with all the options on which i think would have been even more annoying trying to find the options that you want.
papaschtroumpf
  • Have a Cow!
« Reply #36 on: November 13, 2003, 12:38:58 am »
auto-hiding the taskbar takes care of the window not quite fitting in the screen.
I do have a problem though: the "save" options in the File menu are grayed (greyed ;) )out and the program doesn't save my changes even though I made some changes (changed layout and changed # of emulators to display.
Dave Butler
    • MAMEWAH Setup
« Reply #37 on: November 13, 2003, 04:32:25 pm »
The Layout Filename/Folder does not seem the want to save but when i alter the 'No Of emulators to display' the Save MAME Wah Settings becomes enabled so it should save. I've clicked, scrolled and even used the cursor keys and the menu gets enabled every time.
So if you change your layout folder then change # of emu's it should save.
I'll fix the layout folder on the next update ;D
chris_lemasters
  • Last login:May 06, 2023, 03:46:18 pm
  • Hot solder, coming through!
« Reply #38 on: November 18, 2003, 01:39:16 pm »
I tried running the setup program on a clean install of XP and Mamewah (but forgot to run mamewah to default config files) and that will create a runtime 0 error (in case anyone gets that error).
Thanks for this great program!
Somebody stole my Rocket Sauce...
You saw my Rocket Sauce and took it all!
 - Tenacious D
jginiso
  • Last login:January 23, 2009, 01:41:17 pm
« Reply #39 on: December 01, 2003, 03:23:18 pm »
Installed and this program is very helpful. I have a question about upgrading Mamewah through this program. I have v0.954b installed and downloaded and unzipped v0.962. I pointed the program to the v0.954b exe. To upgrade to v0.962, do I just need to point the program to the v0.962 exe? When I tried that my machine seemed to lock up and I had to force quit. When I relauched mamewah, my emu1 CFG was corrupt. Will the program update all of the CFG files on its own? Thanks for any help.
James
