Author Topic: arcade monitor wire harness help  (Read 1601 times)
KonkeyKong
  • Last login:October 10, 2021, 09:57:07 pm
  • Monkey is my business and business is good.
« on: October 27, 2012, 05:21:02 pm »
Hopefully pictures soon - camera charging.
My son and I were rotating the 29" monitor on a Nanco Exceleena Red candy cab when I heard him say "oops".  A cable got snagged and the pins got pulled out of a molex connector.  The intact connector that is attached to the monitor has 5 wires: yellow, black, green, gray white, in that order.  The gray and white wires run to one connection point on the monitor board, while the yellow, black, and green wires run to a second connection point further away on the board.
The cable that got pulled comes from the cab and only has 4 wires: yellow, gray, white, purple, order unknown on the pulled end.
Everything was progressing quite smoothly until this literal snag.  Any assistance would be extremely appreciated.
« Last Edit: October 27, 2012, 05:59:41 pm by KonkeyKong »
