Author Topic: Vector questions  (Read 2145 times)
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
Vector questions
« on: October 06, 2012, 08:56:57 am »
So as I understand it an Image must be "vectorized" before making it much larger in order to avoid artifacting ect ect...
So how do I vector an image using P-shop, Gimp or a link to a good on line program that does it for you?
all advice is appreciated. m I am much better with photoshop, I just have Gimp to view .psd on my laptop (P-shop is on my desktop)
Thanks all
t3design
  • Last login:January 02, 2026, 12:17:49 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
Vector questions
« Reply #1 on: October 06, 2012, 09:02:21 am »
Vector magic is an online service that actually works very well. There is a charge to download finished product but it is reasonable.
Once it is vector you need vector software to edit or manipulate it. Photoshop has a vector element in the path function but it is not vector software.
Illustrator is an example.
T3
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
pharoah007
Re: Vector questions
« Reply #2 on: October 06, 2012, 09:49:02 am »
T3
thanks for the input.
So what I understand from this is that P-Shop is not able to fulfill my needs in regards to creating a vector OR manipulating it :(
« Reply #3 on: October 06, 2012, 11:31:10 am »
T3
Not quite, you can create and manipulate vector images in photoshop using Paths but photoshop has a limited arsenal of tools to handle vector images as it is primarily a raster editor.  Illustrator is designed for working with vector so it's easier and to tools are better.  I do a lot of vector work in Photoshop.  If the image is only 4 color or less I'll just layer the parts I need, create paths, and export as needed.  For a full color image needing to be vectorized I'll use a service or drop into illustrator and start tracing and recreating as doing that in photoshop becomes very cumbersome based on how paths are handled by the software.
If you want to stick with Pshop google: vectorize in photoshop or vector tutorial photoshop and you should get some useful results from the myriad of Pshop websites out there.
http://www.teamphotoshop.com/articles-The-Techniques-Creating-a-Vector-image-in-Photoshop-5,8,101a.html is a good place to start
« Last Edit: October 06, 2012, 11:35:38 am by Le Chuck »
