Author Topic: Wg k7000 resolution help  (Read 7676 times)
Furry131
  • Last login:January 10, 2020, 10:55:54 am
« on: September 30, 2012, 10:52:16 pm »
Hey guys. I need help. I'm pretty sure I have a wgk7000 series monitor.  I found pictures that is very close to my board.  Anyhow I have golden tee 2004 fore that I just installed. If you look at my pics they look like they look like they are std res. I'm not 100% sure this is a med res monitor   The pictures will show all of the tags I can see.  I would like to set this to med res if I can. But I am not sure how to. If I can.  Can you please help.
Furry131
« Reply #1 on: September 30, 2012, 10:58:14 pm »
Please help
Furry131
« Reply #2 on: September 30, 2012, 11:15:56 pm »
I also have tekken 3 set up on this screen and it looks great no issues.  The color looks great on tekken but horrible on gt.  looks like I'm playing the fog all of the time
epicfatigue
  • Last login:May 15, 2016, 08:16:08 pm
    • http://www.retromods.com.au
Re: Wg k7000 resolution help
« Reply #3 on: September 30, 2012, 11:28:05 pm »
Thats a WG k7000 and i believe its a standard Res if it helps.
What size is it?
i believe the only medium res they made was K7500 - 25"
and standard/med were
K7600 - 39"
U5000 - 25"
I have no idea what that little pcb is thats mounted next to your flyback could you take a closeup of it?
« Last Edit: September 30, 2012, 11:43:14 pm by epicfatigue »
Furry131
« Reply #4 on: October 01, 2012, 12:06:56 am »
It's 25 inch!!
Furry131
« Reply #5 on: October 01, 2012, 12:07:44 am »
Also what is the fly By.  Not to versed on this stuff
epicfatigue
« Reply #6 on: October 01, 2012, 01:01:02 am »
flyback is the big black thing on the left hand side with two knobs,  it has the annod cup that atachs to the monitor.
it adjusts brightness and focus of the tube, and can kill you if you tuch under the cap,
Furry131
« Reply #7 on: October 01, 2012, 01:05:53 am »
Oh ok my wife and I adjusted the brightness tonight to see if the would help.  We also used the The focus.  It didn't work at all. The pbc is a color adjustment board.  Most of the knobs varied from green to blue.
So I might be stuck with they fuzzy screen until I update my monitor huh??
mgb
  • North East, US
« Reply #8 on: October 01, 2012, 07:40:08 am »
if one board looks great on the monitor and another doesn't, then it may be a board issue.
I have had an issue with a Gt once where it looked like the colors were all messed up. the monitor was fine but the board was giving the issue.
There is a test menu in the GT that may show something wrong.
GT can be set for standard or medium res. but thats not your problem here.
Furry131
« Reply #9 on: October 03, 2012, 10:20:00 pm »
Hey thanks for the help. My dumb arse had the composite sync grounded!!! All fixed.
mgb
  • North East, US
« Reply #10 on: October 03, 2012, 11:15:31 pm »
Congrats on getting it fixed.
techn0
  • Last login:May 04, 2013, 05:25:31 am
  • I fix things.
« Reply #11 on: January 28, 2013, 03:12:54 pm »
I have a k7000 with a goldentee 2005 and it to looks like I am playing in the fog exactly like this.  I performed a cap kit on the chassis and it looks the same.  Are you saying that you fixed it with something related to the sync signals?  can you be more specific?
Chris
Furry131
« Reply #12 on: January 28, 2013, 06:03:23 pm »
Well I was having sync issues but the biggest issue was my daughter board that has the contrast pots on it was broken. I replace the board and adjusted the contrast and bright and spent some time on my colors. It fixed the issue.
Furry131
« Reply #13 on: January 28, 2013, 06:11:16 pm »
Edit. Also make sure you put the sync in the correct spot. I have mine on -v sync and -h sync.  One of my issues is it was grounded.
techn0
  • I fix things.
« Reply #14 on: January 29, 2013, 01:36:28 am »
Well my sync is correct already then.  My screen with goldentee 2005 just looks exactly like the two pictures you showed.  Foggy.  I adjusted for a good white but the brightness had to be increased other wise the colors are too faint.  Then you end up with a very washed out image.
Furry131
« Reply #15 on: January 29, 2013, 08:58:13 am »
Is your contrast working?   Mine did the same exact thing.  I could turn my contrast and nothing would happen. As soon as I changed that board, my contrast worked and I was able to balance out my bright so it wouldn't wash out.
« Last Edit: January 29, 2013, 09:00:17 am by Furry131 »
techn0
  • I fix things.
« Reply #16 on: January 29, 2013, 03:31:55 pm »
I do not have a remote adjustment board with my K7000 but I will have to check tonight after work to see if I have any contrast adjustment.
Furry131
« Reply #17 on: January 29, 2013, 04:00:28 pm »
Ill tell you what. I will take some pictures of the back of my chassis and show you what mine looks like. I know its possible not to have a remote board and just have the pots on main board but from what I understand its more likely to have one.   here is a location of where you will find the WG manual   looks like the far right is where the pot is suppose to be for the contrast.
http://files.flipperspill.no/Support/Arcade/Monitors/Wells-Gardner/?C=M;O=D
i hope this helps for now.
techn0
  • I fix things.
« Reply #18 on: January 30, 2013, 12:02:23 pm »
Ok well I feel like a bit of an idiot because I know I did a little adjusting of the contrast at some point in my trouble shooting but I noticed that it did not make much of a difference.  Well after talking to you I was going to check this contrast thing out a little more.  Turns out that when turned all the way to one side the picture instantly looks amazing in comparison to how it has been looking.  So now the only thing that is not quite there yet with this monitor is my ability to adjust the vertical position where I want it.  The knob gives me about 1/2" adjustment and it is almost to low to read distance to the pin in golden tee.
Furry131
« Reply #19 on: January 30, 2013, 12:39:55 pm »
LoL. :applaud: Sounds like your issue is the vertical size pot or your vertical raster pot....  they are the 4th and 5th pot from the right.   it may be something else but I would make sure and fix everything you messed with before you go any further.... can you take a picture of your screen and what it looks like.   maybe the monitor chassis too.
techn0
  • I fix things.
« Reply #20 on: January 31, 2013, 12:14:33 am »
Here is a picture I took with the lights off to avoid the flash reflection.  You can see how it would be nice to adjust the image higher but that is as high as it will go.  I also took a picture of the monitor chassis.
Furry131
« Reply #21 on: January 31, 2013, 09:03:22 am »
Sounds like your pot is not working right.  I would create a new post here in the monitor section.  Tell them what your issue is. I'm sure someone with more experience can help you some more. Glad it looks better though.
techn0
  • I fix things.
« Reply #22 on: January 31, 2013, 11:37:51 am »
OK sounds good. Thanks for your replies.
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #23 on: February 01, 2013, 04:00:36 am »
has this chassis had a cap kit.
if not it needs one to look it's best.
try adjusting your 50/60 htz pot.
first center your V-size and V-position pot  then adjust your  50/60 htz pot.
and finish the adjustment with your V-size and V-position pots.
with this combination you can get the best image that the chassis will do.
there are many K7000's that need this adjustment done and even then will never adjust all the way up.
why i do not know but it is one of the few quirks that theses chassis have.
also check out my youtube channel for monitor repairs i have done.
https://www.youtube.com/user/buffett1978?feature=mhee
Peace
Buffett
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
techn0
  • I fix things.
« Reply #24 on: February 01, 2013, 12:08:37 pm »
Yes it has a newly installed cap kit.  All but ceramic disc type C204 on neck board because when I first fired it up there were major issues that I thought might have been caused by c204 so I reinstalled the original.  The problem ended up being related to a broken resister that I damaged when I was removing some of the white goop holding one of the original caps in place.  I have since replaced said bad resistor but have not tried replacing C204 again. I have not adjusted the 50/60 hz pot either.  I thought I remember seeing that it was white gooped to prevent adjustment but it may have been another pot.
buffett
« Reply #25 on: February 01, 2013, 03:15:09 pm »
as a general rule you never change a part from one type to another unless it is a known upgrade.
the 50/60 htz pot should never be glued down.
the only pot that is, is your HV shutdown pot.
Peace
Buffett
Furry131
« Reply #26 on: February 03, 2013, 05:08:25 pm »
Peace
Buffett
Thanks Buffett I checked out my monitor today and adjusted the 50-60 hz pot today and now my screen looks great!!!!!!
buffett
« Reply #27 on: February 04, 2013, 06:47:10 am »
sweet excellent job!!
glad it was an easy fix.
Peace
Buffett
Furry131
« Reply #28 on: February 04, 2013, 08:39:27 am »
Hopefully this helps tech0 also!
techn0
  • I fix things.
« Reply #29 on: February 11, 2013, 05:58:13 pm »
I did play around with the 50/60 pot and it sort of helped but not enough for me to consider it good to go.  There must be some components that need to be replaced to give me the ability to center the screen properly.  The way it sits now is still a huge improvement over how it was before entering this thread.  So I appreciate the help.  Thanks
buffett
« Reply #30 on: March 06, 2013, 08:20:38 am »
try increasing the value of R83 or remove R83 and see if you get your image to shift up where you want it
check out my YouTube channel to see what it do.
Peace
Buffett
