Author Topic: mamewah: shortcut to DOS program?  (Read 2995 times)
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« on: October 10, 2003, 04:37:13 am »
I wanted to add a video poker to my list of apps in the PC "emulator" but I don't know how to create a .LNK from a DOS file, windows seems to insist on creating a .PIF file.
How do I work around this?
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
Re:mamewah: shortcut to DOS program?
« Reply #1 on: October 10, 2003, 09:16:01 am »
Can you create the PIF and then create a shortcut to that?
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
papaschtroumpf
  • Have a Cow!
« Reply #2 on: October 10, 2003, 11:20:23 am »
The new shortcut is still a PIF file
« Reply #3 on: October 10, 2003, 01:05:13 pm »
I hadn't thought of that  ::)
What happens if you change the ROM Extension from LNK, to PIF - does the program launch properly??  (I have not tried it myself).
If so, you may just have to use a separate list for PIFs.
papaschtroumpf
  • Have a Cow!
« Reply #4 on: October 10, 2003, 02:22:53 pm »
Yeah, I though if that but haven't tried it yet. Not thrilled about having to switch emulators though.
Maybe there is a way to create a PIF file for programs that would use a LNK file normally (for example adding a batch file in front of them?)
I'll play with it this weekend.
By the way, is there a "hot key" to switch between emulators or do you have to go in the menu?
« Reply #5 on: October 11, 2003, 07:37:16 am »
Well if you let me know if the PIFs will launch OK, I can make PC lists look for LNK's and PIFS...
'4' by default switches emulators.
papaschtroumpf
  • Have a Cow!
« Reply #6 on: October 12, 2003, 08:17:23 pm »
would it be possible to add multiple extensiosn in the "ROM EXTENSION" specification? for example one might like to run LNK, BAT, PIF,... Maybe that's what the LNK method was suppose to avoid?
(by the way, I haven't tried PIFs yet, I took my MAME machine apart to replace the keyboard hack with a keyWiz and do some rework. I will try it soon though)
papaschtroumpf
  • Have a Cow!
« Reply #7 on: October 12, 2003, 11:20:46 pm »
I can't seem to get the PIFs to work.
I setup a directory with a link to poker.exe inside (the link is a PIF because poker.exe is a pure DOS program)
I then pointed the ROM path to that directory and changed the ROM extension to PIF.
It works find building the list but when I try to run it I get a run time error with a big long negative number (I can try it again and send you that number if you want) the error "message" is simply "T".
I think that there may be options to PIF files in windows so I'll see if I can play with those.
Also when I run the PIF directly from windows, when the program exits I get a "finished" DOS box on the screen, so I may have to deal with that also.
« Reply #8 on: October 13, 2003, 08:36:48 am »
I had a feeling the PIF's wouldn't launch :(
I'll have a think about what to do...
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #9 on: October 21, 2003, 12:41:53 pm »
How about a key for selecting the previous emulator?  That would be just as useful!!!
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
papaschtroumpf
  • Have a Cow!
« Reply #10 on: October 21, 2003, 01:26:00 pm »
Yes it would, I had a test setup with too many emulators and it was a pain to have to go around the loop to get the previous one. (this was only a test though, I don't have that many emulators at the time)
JackTucky
« Reply #11 on: October 21, 2003, 01:49:45 pm »
what is the shortcut for next emulator?  What is the shortcut for QUIT?
« Reply #12 on: October 21, 2003, 04:11:02 pm »
Next emulator is '4', quit is Escape.  Both can be remapped in Control Options > Customise Controls.
Bizzarely, I never even though of adding a 'previous emulator' key...maybe because I only run 3 emulators max.  I'll add it some time :)
Luxury
    • arcadeZERO
« Reply #13 on: October 21, 2003, 07:22:59 pm »
maybe we should remind you in here:
http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=12379
 :D
JackTucky
« Reply #14 on: October 21, 2003, 07:59:46 pm »
I thought there was a shortcut key to exit out of Minwah and take the default option (which for me would be exit and shut down)
Thanks, Art
papaschtroumpf
  • Have a Cow!
« Reply #15 on: October 22, 2003, 01:15:44 am »
isn't it what the ESC key does?
« Reply #16 on: October 22, 2003, 04:22:35 am »
 :D
Not sure what you are referring to in that thread (it is early)  ::)
« Reply #17 on: October 22, 2003, 04:24:05 am »
???? Escape...
