Author Topic: Madcatz SF 4 SE LED MOD HELP!  (Read 7623 times)
Choppaholic
  • Last login:November 15, 2012, 12:19:17 am
« on: September 24, 2012, 11:18:08 am »
What's up forum...I'm new to this whole fightstick world and I hope I'm posting this in the right place but I finished my first mod last night minus my led mod...I can't figure out why it isn't working...I'm using a sparky PWM SMD LED controller and I'm using uila leds with it...I only have one button out of 8 lighting and its only a solid green...not any of the other colors..all the buttons have power and are functional just not lighting up..I've checked all the grounds on each button but everything looks good..can any of the experienced modders offer any help?...id sure apprciate it..
northerngames
  • Trade Count: (+18)
Re: Madcatz SF 4 SE LED MOD HELP!
« Reply #1 on: September 26, 2012, 06:47:10 pm »
personally I would straight wire them off a 3.3V or use a 5v with a resistor and have a switch under the cp if your just lighting them is all.
no clue what those are that you mentioned above so I cannot help with any of that sorry.
GibsonRiddler
  • Last login:May 21, 2025, 03:38:19 pm
« Reply #2 on: September 26, 2012, 10:01:43 pm »
Might want to try the shoryuken forums. They are geared more for the fight stick mods. Most of what you will find here is arcade builds.
http://shoryuken.com/
I need a house to put stuff in, instead of an apartment with stacks of boxes.
« Reply #3 on: September 26, 2012, 10:26:46 pm »
GibsonRiddler
« Reply #4 on: September 28, 2012, 04:56:06 pm »
Choppaholic
« Reply #5 on: September 28, 2012, 06:30:36 pm »
Thanks alot for your help...I checked on srk but found that if I don't have a engineering degree I couldn't understand much of what they were talking about...I was going off a tutorial where the guy installed the led board with no issues and made it sound easy..and during my research of the product saw that it wasn't that hard...but now I found out that there is programing involved and other parts..I like the straight hardwire idea...wire them to a switch and have them run..thanks again..
Choppaholic
« Reply #6 on: September 29, 2012, 12:00:24 pm »
I just tapped into 5V from USB: http://forum.arcadecontrols.com/index.php/topic,113154.msg1201658.html#msg1201658
[/quote your led mod looks great...where did you get all your supplies like the Molex connectors and power switch?
« Reply #7 on: September 29, 2012, 12:45:51 pm »
Thanks. Got the Molex parts direct from Molex, switch off ebay, buttons and LEDs from Paradise Arcade.
Choppaholic
« Reply #8 on: September 29, 2012, 10:34:52 pm »
Yup..I'm going to try and get a refund on my sparky pwm and buy some supplies and do it the way you outlined in your tutorial.
Choppaholic
« Reply #9 on: October 14, 2012, 08:27:22 pm »
.        I attempted my hardwire mod today and got more of the same...I have power to the switch but when I hook a led to the switch no light..I was still using my uila led lights from focus attack.com I figure that as long as I have a ground and power that I should have light...but nothing..do you have any ideas?..I'd really appreciate it..
« Reply #10 on: October 15, 2012, 09:42:31 am »
Do you have it wired backwards? Do you have a multimeter?
Choppaholic
« Reply #11 on: October 15, 2012, 04:36:38 pm »
.  My switch is labeled for ground, power and lights..but I do have a multimeter..what are you thinking?
« Reply #12 on: October 15, 2012, 05:34:28 pm »
I think you may have it wired wrong. Could you post some pics or a wiring diagram of how you currently have it wired up?
Choppaholic
« Reply #13 on: October 15, 2012, 09:38:21 pm »
.   Alright..I'm running the grounds to the ground from the USB and the power running to the switch from the USB too..ill post a pic ASAP
Choppaholic
« Reply #14 on: October 16, 2012, 03:48:37 pm »
.    I have the power and ground from the usb..the other red wire is the red color wire for the led..the ground for the led is running on the USB aswell..
« Reply #15 on: October 16, 2012, 05:51:42 pm »
Well, that pic is a start, but it doesn't help much. I've attached your pic with some additions. Since I can't see any of the terminal labels on your switch, could you tell me what they're labelled (green, red, and blue arrows)? The terminal labels should be on the switch body, maybe one will be C or COM, the other two might be single letters or numbers or NO and NC. What type of switch is this, a toggle switch? Once you can tell me this stuff, I can tell you exactly how to run your wires to it.
« Last Edit: October 16, 2012, 05:53:58 pm by Nephasth »
Choppaholic
« Reply #16 on: October 16, 2012, 07:14:13 pm »
.   Yeah its a toggle switch...the blue arrow is the ground from the USB and the ground for the led..red arrow is the power from the USB and and green is the color of the led on that button..
« Reply #17 on: October 16, 2012, 07:35:03 pm »
I didn't want to know what wires connected to where, just what the terminals are labelled on the switch itself...
The following is an assumption due to lack of info:
But, the wire you have connected at the red arrow should connect to the LED + wire/terminal. Ground from the usb should be connected to where you have it (I'm assuming since I don't know what the terminals actually are on the switch). The red wire connected at the green arrow is probably fine. Get rid of the black wire going to the LED.
Are you using RGB LEDs or single color? Can you post a pic of the connections on the LED so I can know for sure what your setup is like?
« Last Edit: October 16, 2012, 07:39:25 pm by Nephasth »
Choppaholic
« Reply #18 on: October 16, 2012, 09:48:28 pm »
.   Here's some pics of the switch itself and the LEDs..they are RGB LEDS but I wanted to just test one color
Choppaholic
« Reply #19 on: October 16, 2012, 09:53:57 pm »
 I  really appreciate you going the extra mile and helping me with this man..any help would he awesome..thanks again..
« Reply #20 on: October 16, 2012, 10:42:39 pm »
Weird switch. Does the switch itself light up? Do you have a link from where you bought it (if you got it online)? In the mean time try this. Hook USB ground up the the ground terminal on the switch (the one on the side). Hook up your RGB LED color wire to the + terminal of the switch. And hook up USB 5V to the + wire of your RGB LED.
Choppaholic
« Reply #21 on: October 16, 2012, 11:20:33 pm »
.   Yeah it has a led on the tip of the switch..I just got it on eBay..generic led toggle switch..ill try that wiring and post the results.
Choppaholic
« Reply #22 on: October 17, 2012, 12:13:10 am »
Here's a couple of pics on the wiring..I connected the 5v USB wire to the ground on the led and connected the color wire to the + in the switch and it was really dim...and when I connected the color wire to the ground on the switch it lit up bright but can't turn it off ofcourse..my led wires don't have a 5v power wire just a black ground wire..the other wires are all color wires..
« Reply #23 on: October 17, 2012, 12:24:35 am »
The black wire marked with a + on your leds isn't a ground, that's your voltage in wire. The color wire on the leds are all ground wires. Do you have another wire connected to the switch? The switch shouldn't be lighting up how I told you to wire it…
Anyway, try running usb ground to the switch ground, usb 5v to the + terminal of the switch, the black + wire of the led to the other terminal of the switch (looks like a light bulb), and your color wire (ground) from your led back to usb ground (doesn't have to be on the switch terminal, but can be for testing if needed).
I always switch the ground side of my circuits, but this switch may be designed to switch the voltage side…
« Last Edit: October 17, 2012, 12:26:32 am by Nephasth »
Choppaholic
« Reply #24 on: October 18, 2012, 12:58:59 am »
.  I think we got it...thanks for your help..I am very grateful and I learned something..lol..
Kolhell
  • Last login:November 15, 2012, 05:50:57 pm
« Reply #25 on: October 30, 2012, 04:33:21 pm »
Sexy stick, but I think your pink/red is backwards ;p
