Author Topic: length of vector lines  (Read 2091 times)
SavannahLion
« on: September 20, 2012, 01:14:38 pm »
I can do this is Sketchup, but I'm having some minor problems scaling and printing so I thought I'd look at Inkscape but I  can't quite figure it out.
If I draw a flat image with lines, how do I find the total length of selected lines at the proper scale?
dfmaverick
Re: length of vector lines
« Reply #1 on: September 20, 2012, 03:10:47 pm »
Not sure if I'm understanding exactly what you're looking for, but...
If it is the entire item:
Edit>Select all
The total size of selected items will be displayed.
If you want to then alter that size to a larger/smaller size:
Scale to your desired end size by using Object>Transform. Use "Scale", check the "scale proportionally" box and enter a percentage to get you to the end size
  • Last login:Today at 07:20:12 pm
« Reply #2 on: September 20, 2012, 03:54:12 pm »
Insert a measurement line or box to verify size and/or layout.
If you're worried about accidently messing up the art, add a separate layer for it.
When you're done, just delete the line/box/layer.
I'm assuming here that you already know that you can change the units displayed from px (pixels) to in (inches).
SavannahLion
« Reply #3 on: September 20, 2012, 06:14:49 pm »
Hhhmmmm.... Let me see if i can clarify without resorting to firing up my laptop.
Let's say i want to lay out rail road track.... El wire..... A string of christmas lights.... Um....ah, a wire on a 2D plane..... And rather than actually buying the above mentioned items, i want to set a path then determine the total length of that path. I know the limts of the space I just need to know the length of a line within that space.
In Sketchup this is relatively easy. I'm stumped how this is done in any other program though.
I tried to find this function in inkscapw and visio.
dfmaverick
« Reply #4 on: September 20, 2012, 08:29:56 pm »
I get mixed results with:
Extensions>Visualize Path>Measure Path
(It doesn't seem to measure what it says it does)
« Last Edit: September 20, 2012, 09:15:39 pm by dfmaverick »
« Reply #5 on: September 20, 2012, 09:02:39 pm »
This is a total pain the ass way but if you grid out Hole A's location and Hole B's location then it's a simple Pythagorean problem.  Doing that X number of times can be daunting tho.  I'd do the longest one then SWAG the rest.  There really isn't such a thing as extra wire is there?
SavannahLion
« Reply #6 on: September 21, 2012, 06:05:07 pm »
Well..... there can be if it's relatively costly and splicing is out.
