Author Topic: Makvision 27"/29" Tri-mode tube (viewable area) measurements?  (Read 1724 times)
emuola
  • Last login:June 15, 2017, 02:19:54 am
« on: September 16, 2012, 06:47:21 am »
Hi.
Could someone please tell me the exact measurements of the tube. With the tube I mean the actual effective area that shows something (viewable area);) I have an existing cab, which I'm planning to upgrade and I want to know if the current bezel is big enough.
*edit*
It would be great if someone could also measure the exact maximum width of the tube (viewable + non-vievable). It's impossible to tell from the available images, if the tube is as wide as the mounting frame. This could be a tight fit...
« Last Edit: September 16, 2012, 08:00:15 am by emuola »
Gray_Area
  • -Banned-
  • -Banned-
Re: Makvision 27"/29" Tri-mode tube (viewable area) measurements?
« Reply #1 on: September 18, 2012, 03:19:04 pm »
The viewable area is 27 inches, diagonal. As you know the aspect, you need only know the equation to figure it out.
You can probably find a manual of the monitor in question, or *some* 29/27" monitor, and it'll have a diagram. Maybe of everything.
-Banned-
