Author Topic: chassis - earth  (Read 1892 times)
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
chassis - earth
« on: October 09, 2003, 07:14:13 am »
Cheerio all,
Just got a nanao Kz18-en chassis repaired (came non-working with the cab I picked up for cheep).
There was no "frame" for the monitor in the cab - the tube was just bolted in to the plywood, with the chassis screwed into the inside of the cab.
As I am in Oz, (240v AC), I have a step-down iso transformer to take me down to 110v for the chassis.
I'm new to all this, so bear with me: My question is this: the primary side of the transformer is connected to a 3 prong plug (active, neutral, earth), while the secondary side just has a two-prong socket.
So do I need to connect the chassis to earth somehow? Do I just run a wire from the small metal PCB support/frame on the chassis to the transformer somehow??
I'd  appreciate any help
Cheers
bviking
(i'll try to get hold of a digicam for some pics over the weekend).
Shut up! Bloody Vikings!!
menace
Re:chassis - earth
« Reply #1 on: October 09, 2003, 04:48:59 pm »
see this (the topic might be different but the pic is all you need to know)
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=11888;start=msg92443
basically, tie all the earth (green) together and back to the incoming earth from your power supply
