Author Topic: ELECTRICAL: LED powering via PSU  (Read 1457 times)
DrChek
  • Last login:June 23, 2026, 01:40:07 am
« on: September 05, 2012, 02:05:23 pm »
Simple question (I'm no electrician):
I have two of these LEDs that I need to wire for my coin door.
They are rated as 6.3V. Can I power them with the 5V from my computer PSU's molex connector like this?
I realize that they will be dimmer driven by 5V as opposed to 6.3V, but how bad will it be? If bad, than what do I need to do to use the 12V source from the molex connector?
  • Last login:May 30, 2026, 12:00:14 pm
Re: ELECTRICAL: LED powering via PSU
« Reply #1 on: September 05, 2012, 02:12:08 pm »
Yeah, that should work. The link doesnt tell if the dropping resistors are built into the base, but it looks like they are.
If you needed dropping resistors, you could adjust the resistors to account for the lower voltage, thus same brightness, but I dont think 1.3 volts is going to make that big a difference in brightness anyway.
Louis Tully
« Reply #2 on: September 05, 2012, 02:19:40 pm »
« Last Edit: February 12, 2015, 09:36:25 am by Louis Tully »
DrChek
« Reply #3 on: September 05, 2012, 02:20:15 pm »
These are the bases I have and I think you're right.
I fgured it would work as I've seen similar LEDs listed as 5-6.3V on other sites.
  • Last login:Today at 02:15:24 am
« Reply #4 on: September 05, 2012, 02:33:55 pm »
Definitely no problem with your proposed setup.
You won't have any problem with brightness running 6.3v LEDs on 5v.
I run 12v LED buttons off 5v from USB.  They don't burn your retinas, but they do light the admin buttons quite nicely.
