Author Topic: Sharp image 629 ds-r on and off sound  (Read 2163 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: July 28, 2012, 08:16:47 pm »
ok i have this chassis and when it is hooked up it seems to be trying to start but i can hear a light chirp on off on etc. im pretty sure that would indicate a fault at the hot but what i need is a schematic of the chassis. does anybody have this.
GMZombie
Re: Sharp image 629 ds-r on and off sound
« Reply #1 on: August 09, 2012, 09:41:41 pm »
nobody has a schematic for this chassis or knows where i can get one?
GMZombie
« Reply #2 on: August 24, 2012, 11:58:38 am »
 :burgerking:ok went ahead and replaced the hot. Same problem. So I started to check voltages and it seems I get 168v up to c814 on. The side that comes from the ad input. On the otherwise I get about .2 volts dc. This is Tue only point I can see that goes from the power supply side to the other side of Tue board besides the transformer. I checked voltage st the hot and I have none or so minimul u couldn't count it. When u check the voltage at the collector at the hot I notice when I hear the overload of the hot on the meter for a second it will go o/l then back to low volts. Checked at the b+ adjustment pin and it shows 169volts dc. I'm stumped
GMZombie
« Reply #3 on: September 06, 2012, 07:21:23 pm »
nobody can help me with this multi cga/ega chassis?
mgb
  • Last login:March 25, 2026, 09:52:08 pm
  • North East, US
« Reply #4 on: September 06, 2012, 08:49:41 pm »
usually a light chirp indicates a blown flyback (which very well may have also taken out the HOT)
GMZombie
« Reply #5 on: September 06, 2012, 09:51:04 pm »
so is there tests i can do to verify if it is a blown flyback?
mgb
  • North East, US
« Reply #6 on: September 07, 2012, 12:20:33 am »
Not really, ussually it will have a visible crack.
some times if you run it in a dark room, you may see arcing come from the flybacks body.
GMZombie
« Reply #7 on: September 26, 2012, 06:21:01 pm »
so here is a pic of the back of the board. i have written where i took some voltage levels and they all seem to be around 170 vdc. the only thing is after the transformer i dont have any volts and after that cap that i have indicated. could this just be a faulty flyback or should i try to replace this cap first.
