Author Topic: Weird issue..related to Hyperspin?  (Read 2984 times)
GregD
  • Last login:December 23, 2025, 04:38:08 pm
    • Arcade Nebula
« on: June 03, 2012, 12:06:27 pm »
Started playing my cabinet and I am having a strange issue in Hypersin.  It seems to be only happening when the player two controls are being used.  Randomly, probably via some button/joystick combination, the hyperspin session is going to a black screen.  I still hear the game running in the background but cannot get back to it.  Another session opens in the background with the hyperspin wheel.  When I go to the application manager, I see autohotkey blackscreen and also sessions for the mame game and one for hyperspin.  Any idea how to prevent this from happening?  I am using the mame default keys with a keywiz.
Drnick
  • Plodding Through Life
Re: Weird issue..related to Hyperspin?
« Reply #1 on: June 03, 2012, 04:46:20 pm »
Have you disabled Hyperlaunch?   There are a couple of odd issues that can be caused with Hyperlaunch and mame so try disabling it, Especially if using the Q Button. I am Not sure about the trackball spinner issue you reported in your other thread though. I presume you have it setup for Multiple mice and that they work normally in Mame.
GregD
    • Arcade Nebula
« Reply #2 on: June 04, 2012, 07:59:59 am »
Looks like HyperLaunch might be the problem.  I am going to try and disable it or change the exit script keys in the Hyperlaunch.ahk from Q & S to something else.  Thanks for your help!
lanman31337
  • Last login:January 10, 2024, 10:36:50 am
  • set to ludacris speed!
« Reply #3 on: June 07, 2012, 11:48:21 am »
Change the exit script from q+s to two buttons not used.  It makes it so much easier (found out the hard way when doing it with an ipac)
