Author Topic: CGA to VGA board -- need power supply too?  (Read 2901 times)
jspicher
  • Last login:March 09, 2023, 08:00:47 am
« on: May 25, 2012, 05:51:06 pm »
Hi guys, I can't seem to get a response from jammaboards.com with my question so l was hoping one of you could help me out.
I'm thinking about putting a VGA LCD in one of my cabinets that's got a dieing monitor and l've come across this:
http://www.jammaboards.com/store/cga-ega-yuv-to-vga-arcade-hd-converter-pcb-gbs-8220-gbs-8220.html
My question is, do l need a power supply for this thing as well, or does the board already have that built in? If someone who's installed one of these could tell me what other products (if any) l'd need to buy to hook this bad-boy up that would be a great help.
Thanks for the help guys,
jspicher
Re: CGA to VGA board -- need power supply too?
« Reply #2 on: May 27, 2012, 11:14:12 am »
Thanks grantspain,
What would that look like?
Also, would it "work" or be easier for me if l did purchase one of the power supplies form jammaboards.com to use with this as well?
grantspain
« Reply #3 on: May 27, 2012, 01:08:25 pm »
you just run extra wires from the jamma connector or your existing power supply,you just need +5 and common,its as easy as getting another power supply and cheaper
jspicher
« Reply #4 on: May 27, 2012, 02:28:11 pm »
This isn't a jamma, it's an old school centipede. What does the power supply look like?
