Author Topic: Wells D9500 says "over range"  (Read 2420 times)
zutton1
  • Last login:July 04, 2012, 09:29:16 pm
« on: May 18, 2012, 11:45:56 pm »
New at this so please be kind. I got a space ace cabinet that has a computer in it running Daphne with a flat screen monitor. Not happy how it looks so I want to put in a wells D9500 I have. The problem is when the computer loads xp screen and even set-up screen look fine...when it gets to window screen monitor says out of range. any help on how to adjust this will be appreciated!
Thanks,
DB
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Re: Wells D9500 says "over range"
« Reply #1 on: May 19, 2012, 01:19:31 am »
check your refresh rate in the control panel for the video, try it at 60hz...it might be set to 75hz or something odd.
zutton1
« Reply #2 on: May 19, 2012, 03:01:31 am »
where in the control panel can I find the refresh setting I am using XP...Thanks!
lilshawn
« Reply #3 on: May 19, 2012, 10:36:34 am »
5 seconds with google nets this page" http://pcsupport.about.com/od/videocards/ht/refrate.htm
zutton1
« Reply #4 on: May 19, 2012, 12:12:22 pm »
Ok cool...thanks for the link...was working on this last night for hours. Brain is fried, didn't even think to do a search  :timebomb:
DrArcade
  • Last login:June 10, 2012, 01:23:06 pm
« Reply #5 on: May 19, 2012, 12:22:56 pm »
It's ok, I've personally witnessed a frantic car accident victim calling INFORMATION (411) for the number to 911.
Dr Arcade
lilshawn
« Reply #6 on: May 19, 2012, 03:24:17 pm »
Dr Arcade
 ??? :o ???
what you didn't know they changed the number?! it's now  0118 999 881 999 119 725...3.
