Author Topic: G07 blowing F901  (Read 1818 times)
Coin-Op
  • Last login:July 02, 2012, 06:32:00 pm
  • Yay Whiskey!
G07 blowing F901
« on: May 13, 2012, 10:09:04 pm »
Hey guys,
Have a G07-904 monitor from a ms pac that is dead. The F901 fuse blows. I replaced the HOT and the flyback, put it back together, new fuse, tube on neck of monitor glows purple, makes a crackling sound and the light inside jumps around a lot. After about 30 seconds of this with no picture the fuse blows again and takes the HOT with it usually. I am out of ideas on this one. Any reccomendations as to what might be wrong?
ed12
Re: G07 blowing F901
« Reply #1 on: May 13, 2012, 10:22:20 pm »
hi
Have a G07-904 monitor from a ms pac that is dead. The F901 fuse blows. I replaced the HOT and the flyback, put it back together, new fuse, tube on neck of monitor glows purple, makes a crackling sound and the light inside jumps around a lot. After about 30 seconds of this with no picture the fuse blows again and takes the HOT with it usually. I am out of ideas on this one. Any reccomendations as to what might be wrong?<
the tube is shorted or cracked
ethier way u are causing an arc to ground
on the neck baord is what is called a :spark-gap: it is part of the socket
but from what u have stated ^^^ i would think shorted tube /crack in neck where the gas was let out
ed
lilshawn
  • Last login:August 01, 2025, 03:19:11 pm
« Reply #2 on: May 14, 2012, 12:47:00 am »
i agree, if it's purple INSIDE the neck of the tube, there is an issue with the tube.
it should glow a nice mellow orange, not hot plasma arcs. you may have a short inside the tube or have a crack somewhere and the vacuum has been lost.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #3 on: May 15, 2012, 08:38:58 am »
Gassy tube. Get  a different one....
