Author Topic: Gauntlet II screen tear  (Read 3298 times)
ahofle
    • Arcade Ambience Project
« on: May 12, 2012, 12:21:40 am »
I'm not sure this is a GroovyMAME issue, but I found some strange behavior with Gauntlet II.  There is a vertical line/screen tear on the left 25% or so of the screen.  You can see it right when starting a new game, the 'mortar' between the bricks on the floor is wider along that line.  As you walk to the right, you can see the screen tear along the same line.  It seems more like an emulation error than refresh.  The strange thing is that Gauntlet I has the exact same resolution and does not exhibit this behavior (at least not that I can see).  Does anyone else see the same?
Calamity
  • Moderator
  • Last login:Today at 11:27:46 am
  • Quote me with care
Re: Gauntlet II screen tear
« Reply #1 on: May 13, 2012, 10:57:42 am »
Hi ahofle,
Just tried gaunt2 and I couldn't see the anything of what you describe. Make sure there's no residual video setting affecting this particular game, probably inside the cfg folder.
Steps to create a log:
ahofle
« Reply #2 on: May 13, 2012, 08:05:52 pm »
Wow, once again you are right on the money!
I thought cfg was only for input.  There was some weird stretch setting in there.  Deleted it and now it's all good again!   :cheers:
