Author Topic: Screenshots not showing in Mamewah + Project 64 1.6 not loading games  (Read 2492 times)
pololfc
  • Last login:May 17, 2012, 08:32:35 am
Hi,
I am having a couple of problems trying to run Mamewah with Znes and Project 64 1.6..
1) I'm running Zsnes but i can't see the screenshots for the games. The file is pointing to the correct directory but all that i see is the default image file in Mamewah\config\zsnes\My Layout. Below is my ini file for Zsnes..can anyone see where i am going wrong?
### zsnes.ini (mamewah v1.65) ###
emulator_title                            Snes
### List Generation Settings ###
rom_path                                  C:\Snes\Roms
rom_extension                             smc
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      C:\Snes\zsnesw.exe "[rompath]\[name].[romext]"{dosbox}{safelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       C:\Snes\Snap\Screens
movie_preview_path                        [emuexepath]\previews
movie_artwork_no                          1
enable_fuzzy_search                       1
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
2) When i try to open any game from Project 64 1.6 i get the "attempt to open file failed" message but the game does open outside of Mamewah ok.
Any help would be appreciated.
Thanks,
Mark
pololfc
Can anyone help me with the artwork not showing in Zsnes or the error that i am getting in Project 64 1.6??
Thanks,
Mark
gonzo90017
It has to be an issue with your layout. Go to your Mamewah folder and launch Mamewah Layout Editor> File> Open> Go to Mamewah\config\snes folder. Select the file named "layout". Once opened make sure the "Artwork Image #1" is present and located where your screenshots are supposed to be. If not go to Display Objects> Main Form> Artwork Image #1. Then just place it wherever you want.
