Author Topic: Issues using CGA converter with 1942 board  (Read 4420 times)
Mental
  • Last login:May 18, 2013, 09:46:08 am
    • Complete cocktail arcade system
« on: February 27, 2012, 07:29:04 pm »
I'm attempting to hook a Williams/Capcom 1942 board up to an LCD monitor using one of those GBS-8200 cga to vga converter boards. It displays, but it is shaking vertically (left to right on the game), very badly.
I've read that those converters are hit and miss when it comes to older PCBs. Is there a simple solution to get this working? Maybe a different type of converter? or a sync cleaner?
« Last Edit: February 27, 2012, 11:57:51 pm by Mental »
Complete cocktail arcade system: arcadecabinets.ca
grantspain
Re: Issues using CGA converter with 1942 board
« Reply #1 on: February 28, 2012, 09:29:14 am »
have you tried holding DOWN/AUTO to auto scan?
Mental
« Reply #2 on: February 28, 2012, 11:57:40 am »
No, just pressing it. It didn't help. Does holding do something different?
grantspain
« Reply #3 on: February 28, 2012, 12:01:24 pm »
you have hold both the "down" and "auto" button to autoscan frequency,not sure if you do it on power up or during normal operation-i think you just hold both buttons for a few seconds(been a while since i worked on one of these)
Mental
« Reply #4 on: February 28, 2012, 01:53:00 pm »
[/quote]
[/quote]
Pressing it seems to rescan (no change). Holding it seems to reset to defaults (no change).
It either can't sync properly with old games, or the sync out of the 1942 is wonky somehow.
I've discovered another guy that seems to have the same issue with a Galaga hooked up to an 8200. Not sure if it's ok to post links to other forums ("GALAGA - some sync problem"). I wonder if this is a common problem.
« Last Edit: February 28, 2012, 02:11:19 pm by Mental »
grantspain
« Reply #5 on: February 28, 2012, 03:57:59 pm »
if you mentioned an snk or namco game then i know they have a slightly wierd sync signal and some monitors need a 5k resistor from video ground to vertical sync
bit stumped with this one,could even be a faulty converter board
Mental
« Reply #6 on: February 28, 2012, 04:54:03 pm »
I had to go by Starburst this afternoon and they kindly threw it on the test bench for me. Everything looked 100%. I think those converters just can't handle some old boards very well.
« Last Edit: February 28, 2012, 05:58:07 pm by Mental »
Mental
« Reply #7 on: March 01, 2012, 11:44:39 am »
Update: I got the image to stabilize once, but for some reason only once, by turning the voltage down on the power supply as low as it would go. The image dimmed slightly, but no more shaking. Next step, try a different power supply and see how it helps.
grantspain
« Reply #8 on: March 01, 2012, 02:26:04 pm »
are you using video ground from pin 14 of the edge connector or just power supply/switch ground?
Mental
« Reply #9 on: March 01, 2012, 02:36:28 pm »
I've tried both ways. It didn't make a difference. I think on the 1942 board, they both come off pretty much the same ground plane.
« Last Edit: March 01, 2012, 02:38:03 pm by Mental »
Mental
« Reply #10 on: March 19, 2012, 05:42:33 pm »
Update: I just tried with a different power supply, and an updated VGA converter, but still get the vertical shaking. Is it possible the board isn't outputting the video 100%?
grantspain
« Reply #11 on: March 19, 2012, 05:48:09 pm »
only way you could prove it is by trying a different game board
Mental
« Reply #12 on: March 30, 2012, 12:37:09 pm »
I just hooked the board up to a new LCD from Nieman Displays and there is no shaking at all. It was also fine on a CRT on the test bench at Starburst. Lesson learned, those cheap Chinese VGA converters are only so useful.
« Last Edit: March 30, 2012, 01:12:41 pm by Mental »
