Author Topic: Homemade Dust Washer  (Read 4053 times)
CWorley
  • Last login:August 09, 2019, 07:44:36 pm
« on: February 09, 2012, 08:30:42 am »
Have any of you ever made your own dust washers? If so, what material did you use and what was your method?
I was thinking about using a 1/16 sheet of acrylic like this:
http://www.amazon.com/ABS-Plastic-Sheet-Thick-Black/dp/B004UBUX5C
Then use a hole saw to cut the outside of the washer and a drill bit for the inside.
Any thoughts/suggestions would be great.
« Last Edit: February 09, 2012, 08:37:01 am by CWorley »
Re: Homemade Dust Washer
« Reply #1 on: February 09, 2012, 08:50:19 am »
Probably not what you're after but I adapted some cabinet pull backplates....
http://forum.arcadecontrols.com/index.php?topic=88515.msg1073324#msg1073324
They've worked great for my cab  :)
CWorley
« Reply #2 on: February 09, 2012, 09:56:44 am »
Those would definitely stand out on my Midway Pacman cocktail...
« Reply #3 on: February 09, 2012, 10:07:43 am »
As I recall, Ond did something kind of similar.
Take some sheet plastic, cut a rough circle from it, then bolt it into a drill press centered and use sandpaper to get the edge clean and finish it out completely circular.
Finally, drill through the center with a 1/2 bit to open it up for the stick.
It'll be completely flat though.. While it's in the drill press you might exp with using a chisel or carving knife on it while it's spinning to etch out a ring or two on it to dress it up a little.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #4 on: February 09, 2012, 10:44:05 am »
For all the guitar players out there...you could make them out of pickguard material. Available in many different styles including pearloid, sparkles, mirror, etc.
http://www.greasygroove.com/categories.php?cat=1626
Note: This stuff is too thick to use under a metal panel, but it'll work fine for top mounting (over the panel). I s'pose if you have access to a mill or something similar you could shave down the underside to duplicate the thickness of a Wico (or similar) washer....
CWorley
« Reply #5 on: February 09, 2012, 11:17:26 am »
How thick is that guitar stuff and what is the usual thinkness of dustwashers?
The black plastic sheet I'm looking at purchasing is 1/16" thick.
boardjunkie
« Reply #6 on: February 09, 2012, 11:51:29 am »
Should be about 2.5mm or 3/32".
CWorley
« Reply #7 on: February 09, 2012, 01:22:51 pm »
Are you talking about the guitar material or the usual thickness of a dust washer?
boardjunkie
« Reply #8 on: February 09, 2012, 01:45:57 pm »
The p-guard material is 2.5mm
« Reply #9 on: February 09, 2012, 02:42:20 pm »
FrancoB made some dust washers as well. I think he used a lathe though?
Not sure, but you could hit him up for some information. Or you could probably just buy some off him if he's got any left. Not sure if he has clear though.
edit:  Also, if you really wanna pimp out your panels, you could go for a clear dust washer with an itched image in it:
http://www.tek-innovations.com/arthobbies/index.cfm?loc=about&sub=customd
I'm planning on doing this for some of my panels.
« Last Edit: February 09, 2012, 02:45:27 pm by opt2not »
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #10 on: February 09, 2012, 07:00:27 pm »
Those are sweet looking. When I read the title I thought about how cool it would be to have ryu on player one and ken on player 2 facing each other. When I saw the etched ones I thought for sure they would be priced at something stupid but at $3.75 that's definitely worth it. Not something I think I'd get for my cab being a bit of a minimalist when it comes to art and design but if I had the artwork to support it then those would be the cherry on top.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #11 on: February 11, 2012, 04:05:38 am »
Happ dust washers look just like that material he linked above.
-Banned-
