Author Topic: any advice on programing the esc key..?  (Read 1727 times)
walls83
  • beer is good
« on: September 23, 2003, 05:01:34 pm »
I have everything programed but the esc key  when I go to program it as you all know when in mame32.  When I go into The input keys(general) the esc key exits the program so I cant program it.  How can I program the mame32 to esc games using the "J" button.  Sorry if this is a little confusing Im in a hurry I have to leave.. thanks
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:any advice on programing the esc key..?
« Reply #1 on: September 24, 2003, 02:30:47 am »
Go to "Input (general)", move down to "UI Cancel" (usually mapped to esc), press enter (or what you mapped to "UI Select"), press the "j" key.  Now "j" is your "UI Cancel", aka "esc", button.
FWIW, technically it's wrong for all of us (me included) to call the "UI Cancel" button the "esc" button, and the same with "tab", "enter", etc, but "esc" is usually synonymous with "UI Cancel", and it's so much easier to type 'esc' vs 'UI Cancel', and for newbies to understand "esc key" vs "the key (or button) mapped as the UI Cancel input". [shrug]  A simple learning curve means more learning later.
An other option, you can use the ctrlr ini files instead.  See docs/ctrlr.txt or easyemu for more info.
Robin
Knowledge is Power
walls83
  • beer is good
« Reply #2 on: September 24, 2003, 12:03:20 pm »
Nice thanks,  I cant believe I overlooked that.  Now my CP is fully functional..
