Author Topic: PC -> arcade monitor nightmares. Any ideas?  (Read 2790 times)
Lifespan
  • Last login:February 20, 2012, 12:52:22 pm
« on: January 22, 2012, 03:53:03 pm »
I'm trying to get my PC displaying in my Dynamo style showcase cabinet and I can't find a way to make it work.  Here is my setup:
Monitor: 33" Pentranic 1131 (Note I can find no information on this monitor, but it was running a Sega STV so I'm assuming it's just a standard CGA 15khz display)
Interface: VGA through Ultramarc J-Pac
PC Video: Geforce 9400 or ATI Radeon HD 5450 in Windows XP
I started by trying to get things to work using Soft15Khz through the Geforce 9400.  I was having no luck at all, so I assumed it's was my lack of an EDID dongle.  I found the ATI card was the same price as the dongle, so just went for it.
With the ATI card, things are getting more complicated.  After installing Soft15khz (which was successful), I got stuck in a reboot loop.  Uninstall/reinstalling the video driver fixed the problem.  I also tried installing with the 7.12 pixel clock limit and had the same result.  At that point I switched to trying out Powerstrip and tried just getting the Windows desktop to displaying at 320x240 15khz.  Unfortunately no matter what I do, I just can't get it to display properly.  I have attached the closest I can get, which Powerstrip claims is 320x240 at 16khz.
At this point I am completely out of ideas.  Does anyone have any suggestions?
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: PC -> arcade monitor nightmares. Any ideas?
« Reply #1 on: January 22, 2012, 07:02:57 pm »
what bout picking a gc known as highly compatible ? like the 4xxx series .. that would be to easy ?  newer nvidias need a dongle and 5xxx radeons are known for causing some probs .
Kevin Mullins
    • Me on Myspace
« Reply #2 on: January 22, 2012, 07:53:29 pm »
How about the setup on the Ultramarc J-Pac ?
(frequency jumpers and whatnot)
The double image like that generally means you are still outputting a VGA signal to a CGA monitor, regardless of what Powerstrip says.
Lifespan
« Reply #3 on: January 22, 2012, 09:16:37 pm »
On the J-PAC I've got both the 15 and 31 jumpers on.  When I saw the double, I removed the 31 jumper and the picture is still double.
Lifespan
« Reply #4 on: January 29, 2012, 11:22:58 pm »
Just to close this out, I went ahead and took back the card and found a 4350 Sapphire on eBay.  Plugged it in and on the first try everything was running great!
