Author Topic: Is there a "standard" size for marquees?  (Read 10310 times)
docrings
  • Last login:January 10, 2013, 06:49:04 pm
« on: January 04, 2012, 11:38:24 pm »
In designing my cab, I have a 8"H x 25 3/8"W area for a marquee.
I haven't found a dimension for a "standard" marquee, or plexiglass...
If there was a "most common" size for artwork, plexi, etc., I am at the stage I can make some dimension modifications...
What size did you use?  Did you have to re-size marquee artwork or have it custom sized?
Thanks,
Doc Rings
 8)
tsaylor
  • Last login:April 20, 2019, 05:16:20 pm
Re: Is there a "standard" size for marquees?
« Reply #1 on: January 05, 2012, 12:31:39 am »
My cabinet was originally a Centipede.  Its marquee is just under 6 x 24 (with the retainer the visible area is actually around 5.5 x 23.75).  But I think the custom designed cabs tend to dedicate a bit more space for the artwork.
« Reply #2 on: January 05, 2012, 12:54:59 am »
My marquee is roughly 36" x 12". ;D
docrings
« Reply #3 on: January 05, 2012, 01:35:20 am »
I'm gonna think Centipede is typical... and 36"x12" is gargantuous (!)   :applaud:
Maybe I need to think in ratios:  4:1  or   3:1.  Mine would be about 3.25:1, so in the ballpark  26" x 8" or so...
eds1275
  • Last login:June 09, 2026, 01:06:56 pm
  • Rock and Roll!
« Reply #4 on: January 05, 2012, 03:03:19 pm »
Mine is 5 3/4 x 28 3/4 and it doesn't look bad. I actually think that the size doesn't matter all too much. If you can make it look good, then more power to you. Thankfully free tools available on the internet such as gimp and sketchup are very helpful in making sure it looks good before you put tools to wood.
bkenobi
« Reply #5 on: January 06, 2012, 02:41:29 pm »
Yes, they are always no wider than the widest part of the cabinet.   8)
