Author Topic: TV in cab: shell or no shell??  (Read 2001 times)
mkdevo
  • Last login:February 09, 2024, 09:31:59 pm
« on: September 18, 2003, 09:10:48 am »
for those of you who are using tv's as your monitor in your cab, i was wondering what the majority of you were doing - keeping the tv in its shell or taking it out? is it safe to mount a tv in a cab without a shell? anyone have any examples? tia..
menace
Re:TV in cab: shell or no shell??
« Reply #1 on: September 18, 2003, 10:16:23 am »
Its safe to mount a tv without a shell as long as the tv remains grounded--the reason I left it in a shell though was that I would then have to build some kind of mount for the tube and chassis, whereas the tv shell already has built in mounts that aren't that much bigger than one I would build myself.  Keeps all the components tucked away nicely.
TalkingOctopus
    • My Arcade
« Reply #2 on: September 18, 2003, 09:33:13 pm »
I kept mine in the shell.  The main reason I did this is becuase I may eventually take it out and use it as a TV.  I think a bezel would fit a little bit better if you took it out of the shell.  My 27" bezel from Happ has less than a quarter inch between the bezel and the tv, but it blends very well.
Check out my website in the sig for pictures.
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
« Reply #3 on: September 19, 2003, 10:36:53 am »
Left my TV in the shell, I may one day want to use it as a TV again.  Its much easier to handle and less work while its in the shell.
