Author Topic: Volume control problem  (Read 2855 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: November 06, 2011, 08:41:33 am »
Hi all,
Been a while since I poste here and since my cab is done. On that subject, I have now a strange behavior that I have probably triggered at some point (or my kids since they are smashing all buttons at once). Well, now when I press button 2 a white volume bar appears at the bottom of the screen and when I move the joystick left or right it lower or raise the volume. I may have installed this in the past but wasnt maybe activated. You guys know where it is coming from and how I can change it ?
Thank you !
This is what happen when you dont keep up with your cab config hehe.
Ho and I am running AtomicFE
ids
  • Fighter Captured
Re: Volume control problem
« Reply #1 on: November 09, 2011, 03:48:49 pm »
Is this during a game, from within the FE, or any time at all?
My first guess is that this is occurring when MAME is running, and you have somehow mapped a key to it's volume control.
Check your MAME settings and/or key output from encoder.
In Mame, hit tab, pick Input(general), then Other Settings (depending on mame version, wording might be a bit different).  Volume should be found in the list there.
For your keyboard encoder, there are different ways to test output (check wiki for software to show key presses).
Nataq
« Reply #2 on: November 12, 2011, 09:48:10 am »
Yes just noticed it is in game. Sounds like it should do it! Thanks a lot!
Nataq
« Reply #3 on: November 12, 2011, 10:54:46 am »
Well I dont find a volume option under mame beside "Volume UP" and "Volume Down" that doesnt appear to do a thing. I have noticed that when I map a button now there is a white square around the designated button in the mame menu. Does that mean another button may be stuck or something ?
I still cant get rid of that probleme... grrr
Nataq
« Reply #4 on: November 12, 2011, 11:54:37 am »
Found solution here: http://forum.arcadecontrols.com/index.php?topic=81479.0
Debug mode was the problem somehow.
Thanks anyway!
